Fuel gage issue?
Old May 2, 2016 | 08:29 PM
lpc's Avatar
lpc
7th Gear
Default Fuel gage issue?
Ok, on my 2000 C5 base, I fill the tank and the gage shows full.
The gage will run down to just below a half a tank then the gage will go dead! It drops to passed E like it just went dead. The computer will show low fuel with no remaining miles left.
Anyone with this problem? How do I start, or where should I start to fix this problem?
Old May 2, 2016 | 08:37 PM
Bill Vett's Avatar
Bill Vett
Common problem, the first thing I would do is buy a large bottle of Techron at your local parts store. When you refill the tank when it's near empty add the Techron. It may take more than one tank and bottle of Techron.
Old May 2, 2016 | 08:41 PM
grantv's Avatar
grantv
Happened to me twice in 3 years running nothing but 94 octane Chevron (with Techron). Both times it was when I completely filled up. So... I try to avoid completely filling up.
Old May 2, 2016 | 08:42 PM
lpc's Avatar
lpc
7th Gear
Thank you I will try it and hope for the best?
Old May 2, 2016 | 08:45 PM
lpc's Avatar
lpc
7th Gear
Someone said it could be the fuel sending unit, I hope not.
Old May 2, 2016 | 08:55 PM
grantv's Avatar
grantv
Just throw an amount in that you know won't get you closer to full the next few gas station trips. That'll let you know if it's a real problem.
Old May 2, 2016 | 08:58 PM
Bill Vett's Avatar
Bill Vett
It probably is the fuel sending unit, they get sulphur deposits on them and the Techron may help clean them. Good luck.
Old May 2, 2016 | 08:59 PM
lpc's Avatar
lpc
7th Gear
Thank you, I'm going to try it.
Old May 2, 2016 | 09:10 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
If it is fixable, techron will do the trick. May take several bottles over the course of several tanks. If that doesn't work, you are probably looking at a new sending unit...
Old May 2, 2016 | 09:26 PM
lpc's Avatar
lpc
7th Gear
Does Techron make , or what would you recommend anything over the counter that I could use?
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Techron fixed mine and I haven't had an issue for about 7 years now. I had to use it for about 8 or 9 months. If you can, fill the tank with a big bottle of techron and let it sit for a week or so. If you can let it sit it seems to work better. The key to this is patience.
Old May 2, 2016 | 09:39 PM
JR-01's Avatar
JR-01
Try using Shell V-Power premium gas. It contains the most Polyetheramine (Techron) of any gasoline. It seems to have cured my gas gauge problem.
Old May 2, 2016 | 09:55 PM
Bill Vett's Avatar
Bill Vett
You can get Techron at Pep Boys, Autozone, Advanced Auto. Get the large bottle if they have it or two small bottles per tank fill. I had the problem years ago the Techron solved it and I only use Shell V Power. Never had it happen again.
Old May 2, 2016 | 11:08 PM
This. Hopefully a couple of bottles or so of Techron Concentrate will clear any sulphur deposits. If not, replacement of the sending units may be needed.
Old May 7, 2016 | 01:58 AM
striper's Avatar
striper
I had this originally happen a few years ago. It took two bottles and two fillups and it was cured. It had been okay for quite a while and then suddenly it recently happened again after the car sat for an extended time period. I tried the Techron again but nothing positive happened. I just kept trying it a little longer and then after it sat for a little while again, after I had added the Techron, I suddenly had a properly working gas gauge. Good luck and give it some time.
Old May 7, 2016 | 10:16 AM
JR-01's Avatar
JR-01
I add a bottle of Techron when I put mine in storage over the winter.
Old May 7, 2016 | 11:31 AM
ZigZag's Avatar
ZigZag
Like others have said but get the 20 oz. bottle. And if you can switch over to Shell 93 it will help out a lot.
Old May 7, 2016 | 12:57 PM
JR-01's Avatar
JR-01
Shell V-Power gas has the most polyetheramine (techron) of all the different brands.
To Fuel gage issue?
