Adding Oil to a C5
Old May 3, 2016 | 05:29 PM
StealthStrike42's Avatar
StealthStrike42
Default Adding Oil to a C5
Hey guys,
Probably a dumb question but I just want to make sure I do it correctly.
Vette's throwing the low oil level warning, and it's 3,000 miles away from needing a complete change. This has happened before and my local shop I go to for oil changes just adds a quart of oil for me and charges me $7 (labor included). I don't really have the time this week to get to that shop so I am wanting to add the quart my self. Where do I add the oil? Down the pipe where my dip stick sits?
I've done some googling but only see procedures for a complete oil change when I google, "How to add oil to a c5 corvette"
Model year 2000 if that makes a difference.
Thanks in advance!
Old May 3, 2016 | 05:33 PM
coia96vette's Avatar
coia96vette
Open hood of car
remove the cap that says oil
add oil to full mark on dip stick
replace cap
close hood and enjoy a long drive
Old May 3, 2016 | 05:35 PM
Velocity_Vette's Avatar
Velocity_Vette
I take it you're not that mechanically inclined?...
Oil is added via the oil fill neck on the valve cover. On your fuel rail cover you'll see the "oil cap" (will... well... SHOULD read "Mobil 1 Recommended" with oil weight and viscosity levels).
You will determine how much to add via the hash marks on the oil dip stick. With car turned off pull it, wipe it clean, insert, then pull again and check. If there is no oil on the hash then you at the least a full quart down on oil. Add half a quart, check oil level, add another half or whatever is required, until the oil level has reach the top of the hash marks.
"3,000 miles" until next oil change? How long has it been since last oil change? Do you have an oil leak?
StealthStrike42
Originally Posted by coia96vette
Open hood of car
replace cap
I had a feeling it would be that easy....
Old May 3, 2016 | 05:37 PM
StealthStrike42
Originally Posted by Velocity_Vette
I take it you're not that mechanically inclined?... Just want to play it safe... Maybe playing a little too safe this time
2000 miles. I hope not. Don't see any oil spots ever anywhere I park. I heard this was normal as these cars just tend to consume a lot of oil?
See quote for reply
Old May 3, 2016 | 05:39 PM
chassed's Avatar
chassed
Yikes.....
The pass side of your engine bay...the cap at the corner of the fuel rail cover...it says corvette on it...you can't miss it... Twist it off...remember righty tighty...lefty loosey...twist it to the left to open....next grab your bottle off oil and proceed with the same left opening action...pour it down the opening where you opened the first cap...
Old May 3, 2016 | 05:49 PM
StealthStrike42
Originally Posted by chassed
Yikes.....
Whaaaat? I always thought it was righty loosey, lefty tighty. Wow... No wonder I've always been having to turn everything upside down to open it!
Old May 3, 2016 | 06:13 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
well back some years you would have had trouble getting lugs nuts off Drivers side of Chrysler product ????? (reverse threads on drivers side):toetap :
Old May 3, 2016 | 06:20 PM
StealthStrike42
Lol I've never had a Chrysler product so I wouldn't know
Old May 3, 2016 | 06:28 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
me ether but had to work on a few ??? Maybe that's why I never owned one
Old May 3, 2016 | 06:30 PM
StealthStrike42
Good to know!
Old May 3, 2016 | 06:41 PM
JR-01's Avatar
JR-01
Old May 3, 2016 | 06:53 PM
Vanover's Avatar
Vanover
For the safety of your car go to the auto parts store and ask them to show you how to and oil.im sure they will be glad to help.im sure you don't have a funnel.if you don't know how to add oil,you prob. Don't know how to read the dip stick.
Old May 3, 2016 | 09:02 PM
As far as oil consumption on the C5, some of the six speed '00-01 cars did experience excessive oil consumption. I had a 2000 that had the problem. It was caused by a problem with one of the rings on the pistons and presented itself usually in high RPM conditions, although I did not drive my car at the limit very often. Mine was cured under warranty by replacing the rings.
You don't say what transmission you have or how many miles are on the car, but not all the cars have the oil consumption problem. It could be caused by the rings, a leak somewhere or some other problem. A quart every 2K miles is too much IMO but to find out where the oil is going would mean a trip to a mechanic to get the car checked out. You would have to weigh whether the cost of diagnosis and repair is worth it compared to just adding a quart every so often.
Old May 3, 2016 | 10:11 PM
Forcedvert's Avatar
Forcedvert
Sounds like too much to me, also in my experience you have to be lower than 1 quart low to get that warning light, you should check you oil often to get a handle on exactly when it may be a quart low.
Good luck,
They may not be filling it properly
Old May 3, 2016 | 10:26 PM
StealthStrike42
My apologies for the lack of information. It's an automatic with 75.7k miles on it. If the job of replacing the rings is as expensive as I think it is out of warranty... I'll definitely stick with just adding oil every so often.
Good luck,
Yeah each time I got the light and took it to the shop, they said it needed a full quart and charged me accordingly.
Got it all taken care of, thanks to those who helped
Old May 3, 2016 | 10:42 PM
001pewter's Avatar
001pewter
St.. Jude Donor '17-'18
Cut the guy some slack, he's trying to learn.
To Adding Oil to a C5
Old May 3, 2016 | 10:57 PM
Forcedvert's Avatar
Forcedvert
Not sure what you read? Nobody was bashing him IMO
Old May 3, 2016 | 11:00 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I liked seeing the Babe pouring oil all over her engine
Old May 3, 2016 | 11:01 PM
001pewter's Avatar
001pewter
Seemed to me like a couple were. Maybe I just took things wrong.
