A4 shift indicator and lamp replacement
Old May 7, 2016 | 01:37 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
Default A4 shift indicator and lamp replacement
OK, so I join the crew of persons having replaced the broken shift indicator and lamp on a C5. The fix wasn't too bad. The cause is what IS bad. Take a peek.
Yes, the front signal housings get damaged due to excessive heat from DRL's. Now this too. What are the engineers thinking?
Old May 7, 2016 | 02:51 PM
jcgunn's Avatar
jcgunn
I replaced mine with an LED. Problem solved!
Old May 7, 2016 | 03:10 PM
Smoken1's Avatar
Smoken1
http://www.mamotorworks.com/Corvette...-2004-647898-1
Replacement parts
Old May 7, 2016 | 08:53 PM
BADBIRDCAGE
Me too. Went with Sylvania LED 168 replacement bulb and Ecklers kit that included new diffuser and indicator piece.
Still a bad engineering platform. Light shouldn't melt the diffuser.
Old May 9, 2016 | 11:47 AM
pmr2000's Avatar
pmr2000
Right the bulb is extremely hot, swapped mine with stock but probably will burn out relatively quickly, poor design!
To A4 shift indicator and lamp replacement
