Headlight door problems
Old May 9, 2016 | 06:52 PM
OldGuard's Avatar
OldGuard
Default Headlight door problems
I hope someone can help me out. Yesterday when I started my 2001 corvette up only the right light door opened, it is dark in my garage. After turning the lights on and off manually a few times the left door started to operate.
Now when the lights go off the left light door closes all the way but then there is a noise coming from the left light door. It lasts about 5 seconds and it sounds like plastic gears grinding or not meshing properly.
I have never taken one the light assemblies out or apart. I have a set of shop manuals but I'm not sure what I'm looking for.
Any info or tips would be greatly appreciated. Thanks, Joe
Old May 9, 2016 | 07:49 PM
frsr06's Avatar
frsr06
Sounds like its gear replacement time. I'd also replace the 4 little plastic bumpers. See the attached website for the solution.
http://rodneydickman.com/corvette.html
Old May 9, 2016 | 07:53 PM
Vanover's Avatar
Vanover
Old May 9, 2016 | 08:08 PM
GCG's Avatar
GCG
It seems you probably have a broken plastic gear in the headlights.
Get a kit like this one (pay attention because there are 2 different kits: one for "97 to early 2000" and another for "late 2000 to 2004") and follow these step-by-step directions. You'll save money and they will last forever
You might need these as well (the rubber bump stops).
There is a TSB, that calls for shimming the driver's side motor. The parts needed for this are included in the above mentioned kit.
Old May 10, 2016 | 08:43 PM
OldGuard's Avatar
OldGuard
Thank you guys for the info. I have the parts on order.
To Headlight door problems
