[Z06] Pretty cool dyno app
There is a pretty extensive setup in which you have to calibrate the motion/accelerometer in your smart phone, you have to fill out a ton of parameters on the vehicle you are testing down to your weight, how much fuel, frontal area * Cd, etc and you also have to follow a pretty strict procedure as far as ensuring the phone stays very still during testing.
Long story short, I tried it out last night, and it measures engine horsepower/torque but gives a roundabout estimation of wheel horsepower based on some standard driveline loss percentage, and I got the following results:
425hp @ 5919 rpm, 426.2tq @ 4710 rpm which calculating around a 12% drivetrain loss on a C5Z puts me at 374/375 at the wheels respectively.
The car (an '01 Z) has a vararam intake, carbon air bridge, XS power long tubes (off road), Ti bypass exhaust, and a diablosport tune. Seems like those numbers are pretty darn close to where I should be for my mods, and the reviews I've read from guys who have actually had their car on a dyno say the numbers are within just a couple hp.
Anyway, I am in no way affiliated with this app, (which is why I'm not posting any links) I just thought it was pretty cool, and maybe some of the other members who were curious would want to give it a shot. It could be a useful tuning tool as it will measure differences in hp (or 0-60, 1/8th mile, and 1/4 mile ET) so you will know if you made a positive change. Pretty cool app and thought others may like a heads up.
~17% for automatics
to get crank HP, take RWHP and divide by .85 (manauls) or .83 (autos)
but in any case interesting app
A bone stock 02-04Z typically dynos 355-360rwhp (if memory serves me correctly) which is around a 12% loss from 405; or roughly 50-ish hp.
That is essentially the method to my madness in coming up with my calculated rwhp numbers vs. the measured crank hp numbers, whether I am right or wrong
I used the following:
Weight: 3049 pounds
Displacement: 5.665L
Fuel Capacity: 60.6L
Drag coefficient * frontal area (in m^2): 0.63
Pitch: 3 degrees/G
Gearbox ratios: 2nd 2.07 3rd 1.43 4th 1.00
I left a few fields out as they are either specific to your personal car (tire size, rear end gears, and such) or plainly obvious.
For example when you push your couch accross the wooden floor is a lot easier than accross the carpet. That is beacuse wood has a different friction coefficient vs the carpet. Now whether its you by yourself or 5 people pushing the couch across the carpet, it doesnt change the friction coefficient of the surface. It will move the couch quicker but the carpet still hold its strong friction surface. Then you have all kinds of dynamic frictions, but the most known ones are kinetic and static.
