[Z06] Is Cryogenic processing worth the $?
1- Is cryogenic processing worth the money?
2- What gear would you run for a 500 rwhp 500 rwtq C5Z?
I will be Autocrossing,Road course racing,street driving and a little drag racing.
Im not even sure whats wrong inside other than some shiny shratnel in the oil and clunking and catching sensation like its binding up when i turn
With the 3:42's you end up "kissing" the rev limiter in second, but seldom do you need third gear. If you drop down to the shorter gear you're going to be caught between second and third in several places on lots of courses. Yes, you'll come off of corners with more grunt, but the reality is that you can't plant the pedal coming off of corners with the 3:42 in second without the back end stepping out anyway. Shorter gears would be a waste since you won't go any faster since you'll still be feathering the throttle, and you'll be shifting a lot more, and I'm assuming that you'd be running DOT slicks like Hoosiers. If you're running 200 TW tires you most certainly don't want or need a shorter set of gears.
Put your time and money into setup and handling and seat time and don't bother with the engine or gears for autocross.
If autocross and HPDEs will be your primary focus, 3.42s will be the best fit.
