[Z06] Question
Old May 27, 2016 | 03:01 PM
DTA4's Avatar
DTA4
Default Question
I have a 03 z06 with 13k miles and am wondering how to adjust two things:
1- Back trunk pops open just a little bit when you hit the button but when you close the drivers side door its goes up enough to get finger under to open.. How do I adjust this?
2- Back breaks feel fine but squeak ocassionally when breaking. Can I lube or is there adjusment for this?
Thanks for help in advance!
Old May 27, 2016 | 03:27 PM
Acid666's Avatar
Acid666
I've read you can grease the hinges and adjust the rubber stops for the trunk. I just always open and shut a door to let the air pressure do it for me. From what I've read there should be plenty of people chiming in on that subject if you search a bit for it.
Old May 27, 2016 | 08:39 PM
appliance guy's Avatar
appliance guy
There's a spring you can buy to correct the trunk issue....just google corvette trunk spring...tons of places sell them, got mine off ebay, less than $10
Old May 27, 2016 | 08:41 PM
appliance guy
As far as the breaks....sounds like the car doesn't get driven much, I'd take it out and drive it like you stole it a few times. ..squeeks will probably go away.
Old May 29, 2016 | 01:18 PM
DTA4's Avatar
DTA4
Thanks just ordered trunk springs. Easy change?I am by no means a mechanic.
Old May 29, 2016 | 01:49 PM
appliance guy
Yes, 1 bolt...doesn't get any easier.
To Question
