radiator talk!!!
Old May 29, 2016 | 12:15 PM
momo20's Avatar
momo20
Default radiator talk!!!
so what is the general ideal of a cut down radiator for a supercharger setup or running the standard height (OEM size)? for those that are running the cut down one what are you cooling temps at? i am on the fence as to which one i want to get and would benefit me more thanks
Old May 29, 2016 | 01:43 PM
StingrayRebel's Avatar
StingrayRebel
I have a full size dewitts with a 4" inlet pipe... I would recommend the full size over the cut down due to the added cooling capacity... you can use an aftermarket cradle, spacers, or have the stock cradle mounts cut and rewelded to move the radiator down a bit so that the inlet will fit
Old May 29, 2016 | 02:22 PM
nzcars33's Avatar
nzcars33
I have the Dewitts as well but I also have the Tiger Shark front bumper which lets a little more air in to the radiator and my temps run between 190-210 on 90+ degree days, and I do have a Supercharger. I hope this helps.
Old May 29, 2016 | 02:33 PM
StingrayRebel
I did open the front license plate area so that does allow a little more air to get through but not as much as the tigershark... depending on your intercooler size air will have to flow through that, then your ac condenser, and finally the radiator and air will take the path of least resistance so you can lose a lot of that air around the sides... this is another reason the lower air dam is so important, even more so on a blower car with an intercooler blocking the front, because it is directing air straight up to the radiator... I wanted to box my radiator/intercooler/condenser in with sheet metal to force as much air as possible through them but I don't have any cooling issues so I haven't messed with that yet
Old May 29, 2016 | 04:47 PM
Forcedvert's Avatar
Forcedvert
Mines cut down cools fine with ac on in Florida heat without license plate cut out. I do have separate trans cooler mounted under headlight. Funny I have the cut down radiator but have not changed the inlet pipe yet.
Old May 29, 2016 | 07:08 PM
momo20's Avatar
momo20
i did box in my setup a few weekends ago and it seems to have help with the ecs lower rad support bracket and their top portion in place....just would like the car to cool down quick and with the summer temps right around the corner i would rather not deal with any high temps....thanks everyone so far keep em coming!!!
Old May 29, 2016 | 07:21 PM
momo20's Avatar
momo20
so those who have done the dewitts rad either the cut down the full one do you wish you would gotten the other one vs the one you got..
To radiator talk!!!
