C5 Dependability by year help
Old May 30, 2016 | 11:22 AM
easywolf32's Avatar
easywolf32
6th Gear
Default C5 Dependability by year help
Not sure if this is correct to ask, but I'm in the market to buy a C5, as that is what I can afford at the moment, perhaps a 2005-2007 model, but that would be pushing it.
Which C5 model from 1997-2004 would you say had the best overall mechanics/electronics with the less problems and bugs?
Old May 30, 2016 | 12:37 PM
garline14's Avatar
garline14
In my opinion, you shouldnt focus too much on which year C5 to get, get the cleanest most well maintained C5 in your budget. The early year C5's (97-00) have the abs module which if goes out cannot be fixed but the 01-04 can be repaired. The 03-04 also have the fuel leak problem as well. I have a 98 and have been daily driving for 2 years with no major issues. There is a thread on here that list all the changes throughout the years just do a search.
Old May 30, 2016 | 12:46 PM
Smoken1's Avatar
Smoken1
perhaps a 2005-2007 model...
That would be a C6 not a C5
Old May 30, 2016 | 12:52 PM
friou's Avatar
friou
I agree with garline14 on what he's said. I might have others disagree with me but, and this is just my personal opinion, condition and documented maintenance trump most everything. I spent about a year looking and finally found a '99 vert 6m, 30k last year. Outside of a bad battery, the car has been flawless, no issues at all. Excellent previous ownership and maintenance, I'm sure, play a heavy part in that! Best wishes and good luck on your hunt! PS, Read the stickies at the top of this page for some very important info on C5's.
Old May 30, 2016 | 01:30 PM
myredhead1's Avatar
myredhead1
Two good selling points for the 2001+ years would be a fixable abs module and the ls6 intake manifold on all ls1 motors. The abs unit on my 2000 coupe went south two weeks after I traded in the car for my C6. Thank goodness it was on the dealers lot and not with a new owner.
Old May 30, 2016 | 01:42 PM
easywolf32's Avatar
easywolf32
6th Gear
Sorry, forgot to add C6 when mentioning about a 2005-2007 model..I just corrected it..
Old May 30, 2016 | 01:43 PM
f6john's Avatar
f6john
You guys need to check the tech forum sometime soon. There is a solution for the early EBCM's. Second sticky at the top of the page. One less reason to give the early cars a black eye.
Old May 30, 2016 | 04:12 PM
El original's Avatar
El original
I own a '03 buying it used. My fav has to be the '03 verts so it has my vote for reliability as I find it rock solid. Good luck
Old May 30, 2016 | 04:51 PM
Macleod52's Avatar
Macleod52
2001-2004 would be where you would want to look. You said 2005-2007 would be pushing it so why not play it safe and go with a C5, unless you prefer the look of the C6 and/or are longing for one. Don't make the mistake many do and settle. Get the car you want.
With that said there's nothing wrong with the '97-00 but many things changed on the '01-'04. EBCM may not be repairable. The cost of a used one is outrageous. Steering Wheel Positioning Sensor isn't made anymore so you have to buy used. On the flip side you can get a much better deal on a '97-00 so if price is a concern there's that to consider.
What you need to do is go to the tech section for C5 and C6 and look at all the stickies. That will help you make an informed decision.
Old May 30, 2016 | 08:21 PM
f6john's Avatar
f6john
I can narrow it down even further for you. Some 01's had ring problems some 03 and 04's had fuel tank issues. Most 02's were built while my cousin Bubba worked on the line and I wouldn't buy anything he had a hand in. However he got sick and was off work most of December 01 and all January of 02.If you can find an 02 with a build date of January 15 2002 on the first shift after lunch I can pretty much guarantee you a perfect car, at least when it rolled off the line!!! Happy hunting
Old May 30, 2016 | 08:41 PM
Murray Anderson's Avatar
Murray Anderson
Was Bubba there in '04?? I'm starting to get concerned
Old May 30, 2016 | 08:51 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
I bought a one owner 99 in May of 2014 with 50,000 miles and have had very little trouble with it and love it !!!!!!!!!!
Old May 30, 2016 | 10:18 PM
CalF's Avatar
CalF
After months of research i found a low miles 04 Z06 that had a late build date to avoid the fuel tank issue.The 04 also i believe has the better shocks and steel shift fork 3-4th gear started about mid 2003.
Old May 30, 2016 | 11:33 PM
f6john's Avatar
f6john
By 04 Bubba had moved to Louisville and got on with Ford
Old May 31, 2016 | 12:23 AM
S.C. vette's Avatar
S.C. vette
Veteran: Marine Corps
Hands down, the last year of production; 2004
Old Feb 16, 2023 | 07:59 PM
Capterics's Avatar
Capterics
Without a doubt it is the 2001- 2002 C5. Note; all C5's have hideaway headlight problems. Also, do not play the "Gear Game". It doesn't work. In fact I was about to use the brass gears and low and behold I found the Left and right motors for about $85.00 new on eBay. Wow, problem solved!
Old Feb 17, 2023 | 01:26 AM
stavanger's Avatar
stavanger
Old Feb 17, 2023 | 10:05 PM
jackthelad's Avatar
jackthelad
Why oh why do we keep resurrecting these zombie threads? This one from 7 years ago. Most (all?) other BB's archive stuff after a few years.
Old Feb 17, 2023 | 11:11 PM
Johnny Hardcore's Avatar
Johnny Hardcore
I get a kick out of a lot of these zombie resurrections. So much BS and missinformation it's baffling. Some of them really crack me up with how ill informed comments are.
Especially after 25 years and 148k miles of owning one '99. And about 6 years and 60k miles on two other '99s. And two of my brothers both owning '99's for many years. And you guessed it...none of them fell apart, had balancers fail nor have EBCM issues.
To C5 Dependability by year help
