[Z06] Looking to MS4 Cam
My plans for the car are just, CAI, Full Exhaust and a Cam.
The MS4 cam is an old cam grind and there are much better options out there. Is there any reason why you chose the MS4? The new technology has come a long way and the grinds are much better now than ever.
You say just a cam.....you do realize that with a cam of that size or any cam for that matter especially one that large, you will need many other parts to go with it. You will need injectors, gaskets, springs, possibly lifters, oil pump, timing chain upgrade, among other things that could be necessary or at least a good idea for reliability.
Your best option/bet would be do a LOT of research and I mean a LOT about the specific cam lobes/grinds and everything about them. It would be a good idea to call and speak with someone about your specific goals with the car. Do you want large power, driveability, the cam "sound" and other things?
Just a few suggestions of people to talk to are Tick Performance, Texas Speed, England Green, Tony Mamo, Advanced Inductions, and many many others that are vendors on the site.
What specific reason made you choose the MS4? If you can't honestly answer that question to yourself then you need to research before you make a decision.
Edit: I'll be upgrading oil pump also, I'm not concerned with driveability and I want it to sound good
I am currently in the process of installing an LG G5X2in my 99 SS.... SLP UD pulley will be replacing my harmonic balancer.
Rule of thumb ( and it varies) is A4 114lsa.... M6 112lsa....
Fwiw the new TSP cams are ground on much freindlier cam profiles that don't beat up the valve train so bad.. Also don't forget To check your PTV!!! It gets super tight with the MS4.
Morel makes some very nice lifters in the $250 range or you can go with the JohnsonSLR but there around $450... Either way if your using a monster cam valve float is going to be your enemy and could cause you to bend some valves if **** gets crazy. Run good lifters to control the valve train and id also recommend upgrading to Titanium retainers. Lighter the better!!
Don't forget the trunion upgrade for your rockers.
A 7.400 push rod probably will be fine but check your lifter preload when your assembling the rockers. Super simple to check and is very important to know. There's many YouTube videos on how to check by setting zero lash and counting the number of turns till right. I ended up with 7.350 length to get the preload I wanted and now my valve train is pretty quiet.
The cam is great and makes wonderful power. With Texas-Speed 1 3/4 LT's, Texas Speed off-road catless X-pipe, into the factory Ti exhaust, and a vararam..also 42# Fast injectors, I made 432/417 with an absolutely beautiful dyno sheet and a great torque curve
