AC Question
Old Jun 5, 2016 | 01:26 PM
99 hardtop 08's Avatar
99 hardtop 08
Default AC Question
My 99's ac has not been cooling like it should. The weird thing is the vents on the passenger side blow cold. The drivers side vents are blowing warm to cool air. Any suggestions or thoughts?
Old Jun 5, 2016 | 02:52 PM
2FAS4UU's Avatar
2FAS4UU
...It sounds like the blend door actuators, but it can also be vacuum issues or a bad climate control head unit. Lots of write ups and info in regards to this, I too have the same issue and it's starting to get hot. Time to address it !!...
Old Jun 5, 2016 | 03:08 PM
Smoken1's Avatar
Smoken1
Way to many posts on this..Have you had the system recharged yet?
Old Jun 5, 2016 | 04:22 PM
Sinister-one's Avatar
Sinister-one
Could be the blend door actuators.
Having the same issues with 00 FRC. I need to replace both of my actuators.
Old Jun 5, 2016 | 04:38 PM
Smoken1's Avatar
Smoken1
If it is the actuators there should be a code stored.
Old Jun 5, 2016 | 06:10 PM
Paddy's Avatar
Paddy
Default AC Freon Low
Mine did the same thing - 2003 with only 25K miles . Turns out I was low on Freon. Charged up and it will freeze you out of the car.
Old Jun 5, 2016 | 08:08 PM
99 hardtop 08
Thank you for the info, I recharged it a few years ago. I didn't notice it cols on one side and warm on the other though. I will check the codes for actuators and the Freon. Any advice on where to begin searching for the vacuum? Thanks again guys!
Old Jun 5, 2016 | 11:02 PM
shadowman1's Avatar
shadowman1
The first thing to do is pull codes. See if there are any a/c related ones. I would still do a complete evac and recharge on the system before I did anything/ or replaced anything else, especially since it solved your issue last time. Small/slow leaks are not uncommon on R134 systems.
To AC Question
