98 c5 question
Old Jun 6, 2016 | 01:49 PM
lectroglide's Avatar
lectroglide
Default 98 c5 question
Trying to find out what a"performance axle ratio and performance handling pkg is on a 98 C5 thanx
Old Jun 6, 2016 | 02:23 PM
73Corvette's Avatar
73Corvette
http://www.thevettenet.com/corvette_specs.php?year=1998
Old Jun 6, 2016 | 02:31 PM
lectroglide
ok, what am I missing??
Old Jun 6, 2016 | 02:39 PM
Velocity_Vette's Avatar
Velocity_Vette
There are two different "Performance Axle Ratio" options which are determined by what transmission the car has (automatic or manual, which are slightly different). Typically the stock axle ratio RPO will be listed along with the performance axle ratio RPO.
"Performance Handling Package" honestly is pretty self-explanatory; it's the famous Z51 Corvette handling package (drawing off the Z51 RPO code) which equipped the car with suspension settings and parts with an emphasis on cornering.
Smoken1's Avatar
Smoken1
Umm your profile says you have a C4
Old Jun 6, 2016 | 02:40 PM
jmohn's Avatar
jmohn
Performance axle = 3.15 gearing (as opposed t0 2.73)
Performance handling I would expect is "Z51" package (stiffer springs and sways).
Old Jun 6, 2016 | 02:57 PM
73Corvette's Avatar
73Corvette
It's a link to the options and RPO codes for the 98 Did you look at it?
Old Jun 6, 2016 | 03:26 PM
jackthelad's Avatar
jackthelad
The axle ratios were simple:
Manual trans - 3.42 - no other option.
Auto trans - 2.73 standard, optional 3.15 "performance axle".
Then there were two optional ride/handling packages - Z51 (the performance handling package), with different shocks, plus stiffer all round suspension, and the F45 which used standard springs/sway bars but included selective damping, 3 settings which ranged from softer than base shocks to stiffer than base shocks.
Old Jun 6, 2016 | 03:27 PM
If you have an automatic tranny, the perf gears are 3.15. The only gears available on the manual tranny cars is the 3.42s.
Old Jun 6, 2016 | 03:39 PM
Bennett_C3's Avatar
Bennett_C3
St. Jude Donor '14
What he said.
Old Jun 6, 2016 | 04:00 PM
73Corvette's Avatar
73Corvette
Transmission
Automatic Manual
Type 4-Speed Automatic 6-Speed Borg-Warner
Gear Ratios
1st 3.06 2.66
2nd 1.63 1.78
3rd 1.00 1.30
4th 0.7 1.00
5th NA 0.74
6th NA 0.50
Reverse 2.29 2.90
Automatic Axle Ratio 2.73 (3.15 opt.) Manual 3.42
Final Drive Ratio 1.91 (2.21 opt.) 1.71
Mileage
City (mpg) 17 18
Highway (mpg) 25 28
Old Jun 6, 2016 | 05:49 PM
bruceg2016's Avatar
bruceg2016
left side of trunk lift panel, under it shows you all options for vette, if you have the z51 package and automatic you know you have 3.15
Old Jun 6, 2016 | 06:03 PM
lectroglide
[QUOTE=73Corvette;1592366126]It's a link to the options and RPO codes for the 98 Did you look at it?[/Q
yes I did but didn't make any sense, thanx anyway
Old Jun 6, 2016 | 06:06 PM
lectroglide
A big thanx for the replys
Old Jun 6, 2016 | 10:42 PM
johnson-rod's Avatar
johnson-rod
It's a Corvette.
It's all performance.
Old Jun 7, 2016 | 02:49 AM
My Vette Life's Avatar
My Vette Life
Originally Posted by johnson-rod
It's a Corvette.
Well said and laid to rest.
To 98 c5 question
