ABS-EBCM module
Old Jun 10, 2016 | 09:55 PM
Libra2001's Avatar
Libra2001
6th Gear
Default ABS-EBCM module
A code showed up C1214 on the scanner. I have checked everything. My ABS light is on. Is there away to turn it off manually. Is there another car that has an interchangeable control module compatible to the 2001 Z06 corvette? Or is there a manual turn off control to reset it on the car?
Old Jun 10, 2016 | 10:05 PM
donald4972's Avatar
donald4972
St. Jude Donor '14-'15
Others may be more helpful, but C1214 can be easily repaired by ABSFixer.
Just take off your EBCM, send it in, they return it in a couple days. Call Brandon at ABSfixer, he'll tell you about it, if you don't find a different solution.
https://www.absfixer.com/
Don
