Ground Question- Need help
Old Jun 11, 2016 | 10:26 AM
peteinpa's Avatar
peteinpa
Default Ground Question- Need help
Hi, hoping one of our electrical guru's can answer this question. I am installing a Curb Alert system, they recommend using the hole in the BCM tab for ground. However I am already using it for my LMC5.
The question is I can use that spot for both or do I need to find another ground point for the Curb Alert, if the latter any suggestions?
Thanks in advance.
Old Jun 11, 2016 | 11:06 AM
Macleod52's Avatar
Macleod52
I don't see why you couldn't use the same spot. My only concern is if having both hooked up to the same ground point would prevent the nut from being threaded enough. If the bolt is long enough to get the nut threaded all the way then there shouldn't be any issues.
