Woke up to this
Old Jun 19, 2016 | 11:36 AM
DTA4's Avatar
DTA4
Default Woke up to this
Woke up to this after taking it for a drive after sitting for 2 weeks. I am no mechanic but know it is oil and is not tranny oil. Any ideas where this could be coming from so I dont get raped when take it to shop.
Old Jun 19, 2016 | 11:37 AM
twokbolt's Avatar
twokbolt
Looks like it's close to the differential. Does it have a really pungent odor?
Old Jun 19, 2016 | 11:44 AM
Fed Up's Avatar
Fed Up
"My Dad's a TV Repairman"
Differential output shaft seal within all likelyhood; get a light on both output shafts, although it may be coming from the fill plug- Get a 10MM hex socket on it and check for tightness.
Old Jun 19, 2016 | 11:58 AM
phoneman91's Avatar
phoneman91
Isn't the differential vent on the driver's side of the differential?
It could be just a small amount of the differential fluid venting . My C5 has done that on very hot days when driving at high speed (75MPH) on the highway.
Check and see if the differential is wet on the driver's side top around the vent. If so-you will probably also see a stain of fluid on the driver's side exhaust right before it enters the driver's side muffler.
I think that I can see a stain on your pipe-in your picture. If so--wipe it off the pipe and top of differential (use WD40 to clean the pipe) and see if it recurs after a drive.
Old Jun 19, 2016 | 12:03 PM
jjc508520's Avatar
jjc508520
I occasionally get a few drips out of mine - as long as it's not excessive just keep an eye on it.
Old Jun 19, 2016 | 02:07 PM
Had the leaky seal on the differential output shaft three times on my '00.
Old Jun 19, 2016 | 02:23 PM
1Willy1's Avatar
1Willy1
the leaky diff is common, my last vette had it
I spent a total of $0.00 fixing it because it never seemed to get worse and didn't really bother me
Old Jun 19, 2016 | 08:13 PM
DTA4's Avatar
DTA4
Thanks everyone for the help. Super hot yesterday and was driving on highway back from sons lacrosse tournament. Just keep an eye on it and see what happens fingers crossed.
Old Jun 19, 2016 | 08:27 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
Old Jun 19, 2016 | 09:08 PM
SuperTom's Avatar
SuperTom
Mine was doing the same thing. I replaced the shaft seals on both sides and the cover seal on the passenger side. While I had everything up in the air I popped off the factory vent and now have a hose and breather hooked instead. The factory vent is known to seize up which causes the pressure to leak out somewhere else.
Old Jun 19, 2016 | 10:39 PM
El original's Avatar
El original
When I read your subject I immediately thought you hooked up with someone/something less than attractive! Whew, its only a little oil drip.
Old Jun 19, 2016 | 11:10 PM
ZeeOh6vette's Avatar
ZeeOh6vette
I got a check engine light today so I can feel your pain
Old Jun 19, 2016 | 11:34 PM
SaxyVette's Avatar
SaxyVette
Double pain here my steering rack sprinkles a bit (I add a bit of fluid occasionally) , and my engine check is currently on with a trans code. Trans was rebuilt 2 yrs ago..gggrrrrr
I am officially ignoring both for awhile.
Old Jun 21, 2016 | 08:47 AM
DTA4's Avatar
DTA4
So its looking like going to have to change differnntial seal. How much time for a mechanic to put in and how expensive is part? Anything else I should do why this is apart and getting fixed?
Old Jun 21, 2016 | 11:40 AM
DTA4's Avatar
DTA4
Do you think this leak could be left rear axle seal?
Old Jun 21, 2016 | 12:47 PM
SuperTom's Avatar
SuperTom
Driver side is most common. On mine it was passenger. I did both sides, I figured if one side went the other could soon too.
Old Jun 21, 2016 | 09:54 PM
Mistrezz 06's Avatar
Mistrezz 06
mine does the same during hot days also, specially on long trips on the highway. Crawl under it and take a look, it's the only way to find out. Good luck.
Old Jun 21, 2016 | 09:58 PM
73Corvette's Avatar
73Corvette
Put her nose in it and smack her with a newspaper... she'll never do it again
Old Jun 29, 2016 | 09:11 PM
DTA4's Avatar
DTA4
So I took my 03 z to dealership for oil change and it the leak coming from rear end is coming from differential output seal. I have a mechanic and place to get parts for cost. Can anyone give me lists of parts and fluids (part numbers if you have them)? It will save me a significant amount of $$$$ to buy all the parts needed and just give to mechanic to change. Thanks in advance for the help.
To Woke up to this
