What's this code?
Old Jun 24, 2016 | 06:53 PM
Vanover's Avatar
Vanover
Default What's this code?
40-bcm B 2482 H C
Old Jun 24, 2016 | 07:01 PM
73Corvette's Avatar
73Corvette
B2482 Backup Lamp Relay Circuit
http://www.stengel.net/diccodes.htm
Old Jun 24, 2016 | 07:28 PM
Vanover's Avatar
Vanover
Thank you.ill just go forward
Old Jun 24, 2016 | 08:24 PM
SoAlVette's Avatar
SoAlVette
I have that code as well, is it a blown bulb?
Old Jun 24, 2016 | 09:05 PM
c4cruiser's Avatar
c4cruiser
If you have the lights set up to come on when you unlock the doors with the fob, the backup lights are part of that feature. Use the fob from the back of the car to unlock the doors and look at the lights.
Old Jun 24, 2016 | 09:11 PM
Carl Timonen's Avatar
Carl Timonen
I pulled my DRL fuse and get B502, B507 and B2482. Back up lights still work in reverse.
Old Jun 24, 2016 | 09:20 PM
Greg_E's Avatar
Greg_E
No. It is fault in the control side of the circuit.
Conditions for Setting the DTC:
The BCM detects a low voltage level (an open or a short to ground) in the backup lamp relay control circuit.
The BCM can only test for this condition with the backup lamp relay de-energized.
The condition must be present for 2 seconds.
This thread probably belongs over in Tech.
To What's this code?
