Tire pressure code
Old Jun 28, 2016 | 11:23 PM
Harley6's Avatar
Harley6
From: Phoenix (Fall/winter/spring); Seattle (summer)
2015 C5 of the Year Finalist
Default Tire pressure code
While driving today I got the "Serv. tire mon. sys." message.
Checked the codes and got this one:
BO-RFA C2105 H C
A couple of possibilities: The sensors were rebuilt when I had new tires installed in April. Also, I had the right front off the car recently so I could clean up the brake caliper, but drove it several times without an issue before the message appeared.
So, now what?
As always, thanks for the advice.
Old Jun 28, 2016 | 11:49 PM
Harley6's Avatar
Harley6
Originally Posted by thisMSGgood4me
You say your sensors were rebuilt. By that, I take it you mean the batteries were replaced? That's not an easy thing to do in the sensors for the '01 - '04 C5s. Perhaps the right front sensor wasn't rebuilt properly and failed very prematurely. You might try clearing the code and see if it reappears. If it does, you'll probably have to have that sensor uninstalled and rebuilt again (if that's possible) or just replace it with a new one.
Tire shop called it rebuilt, which I'm sure means batteries were replaced. I cleared the codes but it keeps coming up. I'll call the tire shop tomorrow.
Old Jun 29, 2016 | 12:19 AM
Harley6's Avatar
Harley6
Originally Posted by 8VETTE7
The process of "rebuilding" that the tire shops typically do is to replace the rubber seal, the nut and the schrader valve. Batteries have to be "cut" out of the TPMS to replace them. ie they are NOT a plug and play thing. Here is a link to some pictures of both the early and late year TPMS:
http://forums.corvetteforum.com/1574148527-post10.html
And another link to a thread about replacing the batteries on the early year TPMS:
https://www.corvetteforum.com/forums...batteries.html
I have never read of anyone successfully replacing the batteries on the later year TPMS (01 - 04).
My guess is that your sensors are "original" and at 13 years of age have outlived their expected life (8 to 10 years).
Looks like I'm continuing to learn something new every day with this car. Looking at my tire receipt, it lists a TPMS rebuild kit but there was no charge. I assume they are the original sensors, although at some point in its life a previous owner (there have been two others) bought Z06-style wheels and maybe the sensors were changed then. Is there a way to distinguish original sensors from replacements?
Old Jun 29, 2016 | 12:41 AM
Harley6's Avatar
Harley6
Since there was no charge, they didn't do anything to "rebuild" the sensors. They simply left the existing sensors installed and replaced your tires.
If one sensor has gone out, it's likely others will follow, assuming all four were installed at the same time.
The sensors will have a date of manufacture stamped on them, but obviously you'll only be able to find out what it is by physically looking at them. The stamp will look like a clock (1 through 12) with an arrow pointing to indicate the month, and a number on either side of the arrow indicating the year (i.e., 0 and 3 = 2003). There's a couple of good pics of this in the first link in 8VETTE7's post.
Thank you. You folks are awesome.
Old Jun 29, 2016 | 09:48 AM
Xavierbank's Avatar
Xavierbank
BO-RFA C2105 H C
So, now what?
You might have got it fixed by now, but I had the same code and it was to reset the TPMS or one of the sensors need to be changed
To Tire pressure code
