steering wheel wooble.
Old Jun 29, 2016 | 07:55 AM
Charles 1959's Avatar
Charles 1959
Default steering wheel wooble.
I am sure this has been discussed . I have a little wooble in steering wheel at cruising speeds. Just the wheel, the car seems fine. Tires seem to be wearing fine proper air pressure. Going to go on our first trip to Gatlinburg. Would like to fix it first.
Old Jun 29, 2016 | 08:01 AM
73Corvette's Avatar
73Corvette
Balance all the tires would be my first move...
Old Jun 29, 2016 | 08:44 AM
Steel dragon's Avatar
Steel dragon
Like he said. And when you balance them be sure to look for a bump or knot where the tire might be coming apart. My father in law drove halfway across the US with a shaking steering wheel. Was ready to junk the car until I jacked it up and showed him the goose egg on one front tire. One new tire later and the car drove perfect.
Old Jun 29, 2016 | 08:57 AM
jackthelad's Avatar
jackthelad
Also check for wheel damage. If it has ever hit a pothole, the rim may have a wobble. Spinning it up on the balancer should show that immediately.
Old Jun 29, 2016 | 01:26 PM
Charles 1959
Ok I'll have balance checked. Tires only have around 6000 miles on them.
Old Jun 29, 2016 | 01:30 PM
73Corvette's Avatar
73Corvette
I've left tire places with BRAND new tires on ... turned around and went right back to have them REBALANCED...
Bent rim is a possibility... make sure they look them over good.
Old Jun 29, 2016 | 03:12 PM
2FAS4UU's Avatar
2FAS4UU
.. You might also want to check the condition of tie rod ends, rack and pinion unit, and alignment. A shaking steering wheel can be related to a number of different components that are worn. Good luck !!...
73corvette.....(Quote); I've left tire places with BRAND new tires on ... turned around and went right back to have them REBALANCED...
To steering wheel wooble.
