climate control panel dim
Old Jul 7, 2016 | 04:16 PM
John59's Avatar
John59
Cruising
Default climate control panel dim
Would anyone know this- ? the light it the climate control panel is very dim (blue)..is it normal ? or what can I do to make it brighter ..the radio seems to be ok
Old Jul 7, 2016 | 04:28 PM
73Corvette's Avatar
73Corvette
https://www.corvetteforum.com/forums...splay-fix.html
DO NOT use the forum search... it sucks
Just GOOGLE whatever your looking for and usually you will have several C5 forum section threads and some LS1 or Digital Corvettes come up... just make sure you use C5 corvette in your search....
Oh.. and WELCOME to the forum...
Old Jul 7, 2016 | 05:18 PM
73Corvette's Avatar
73Corvette
Originally Posted by 8VETTE7
Actually you don't need to use the search function on the Forum at all for over 100 different DIY projects for your C5.
Simply look in this thread for a list and the links to those DIY projects:
https://www.corvetteforum.com/forums...l-in-here.html
The thread is a sticky in the TECH Forum so it is pretty easy to find things. JMHO
The dim display project is post #20 in that thread......
Holy Moly... thanks Chuck... For some reason I've never seen that sticky that is AWESOME... well, more reading time...
To climate control panel dim
