St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19
Help me fix my window**
Never had a problem with this car in the 10 years I've owned it 04 CE coupe. Had been sitting for about 3 weeks. Went to drive it a couple days ago and the passenger window won't come down from either switch. When you try from the drivers side you can hear a clicking but that's it. I'm going to guess it's most likely the motor/regulator.
Any ideas would be helpful. Did a search but came up with a lot different unrelated things. Thanks in advance.
with the switch in the down position take the palm of your hand and rap the door panel about middle.
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Oldtimer
I had the exact same thing wrong with the passenger window on my 04. I fixed it this morning. Watch this video. Tap the motor with a hammer where he shows you. This should unstick the motor. This is what I did and the window is working as it should. Took me about a half hour. You do not need to remove the reflector or disconnect the window switch.
That worked for me. Only my window was stuck in down position. From then on I always brought it up a half inch and never left it in the totally down position, just to be safe.
