Do i have a Z51
Old Jul 25, 2016 | 03:08 PM
FGVette's Avatar
FGVette
Default Do i have a Z51
I'm trying to ID my 1998 coupe as to having the Z51 Performance Package. I've read many accounts of this here on the Forum where it is said that the Z51 has drilled and slotted rotors and the Z51 code can be found on the glove box door. My car has the Z51 code listed with all the other codes but the sticker is located on one of the storage compartment covers in the rear of the car not on the glove box door. The car also has solid rotors not drilled or slotted. I do not have the window sticker. It would be helpful to know this when ordering parts.
Old Jul 25, 2016 | 03:22 PM
Ron C!'s Avatar
Ron C!
Earlier car had the sticker in the back, not sure when it was moved to the glove box, but my 2000 has it there. C5 Z51 cars did not come with slotted rotors. Z51 included higher rate springs, better shocks, a power steering cooler and bigger sway bars.
Old Jul 25, 2016 | 03:24 PM
Shambles's Avatar
Shambles
I could decode the VIN and see if it's on the options that came with your Corvette.
Old Jul 25, 2016 | 04:42 PM
No C5 came with drilled and slotted rotors from the factory. As for the RPO decal, I do believe the '98s had them under one of the compartment covers in the back. If yours says Z51, then that's what is on your car.
Old Jul 25, 2016 | 05:11 PM
73Corvette's Avatar
73Corvette
If I remember you have the F-45 select ride, OR the FE1 base or the Z51 but NOT both...so if you don't have the select ride button on the console it's either the FE1 or Z51...
Old Jul 25, 2016 | 05:17 PM
Rob 02's Avatar
Rob 02
Z51 has a power steering cooler behind the radiator and thick sway bars 28.6mm front 23.6mm rear.
Old Jul 25, 2016 | 06:25 PM
f6john's Avatar
f6john
Contact the NCM and order the build sheet and window sticker for your car if you don't have them. That should answer all your questions.
Old Jul 25, 2016 | 06:31 PM
Fed Up's Avatar
Fed Up
"My Dad's a TV Repairman"
This is the quickest way to check if the RPO sticker is missing.
Old Jul 26, 2016 | 08:16 AM
Big Vig's Avatar
Big Vig
Any more info on how much it is?
Old Jul 26, 2016 | 08:24 AM
FGVette's Avatar
FGVette
Thanks for all your help.
Old Jul 26, 2016 | 09:15 AM
f6john's Avatar
f6john
Build sheet members $35.00 non members $45.00
Window sticker members $75.00 non members $90.00
Check out the NCM website, lots of options available too. A little pricey but great to have the availability to obtain these items for these cars.
Old Jul 26, 2016 | 09:37 AM
jackthelad's Avatar
jackthelad
98 RPO sheet is under the left hand compartment cover in the trunk.
Old Jul 26, 2016 | 10:28 AM
73Corvette's Avatar
73Corvette
So... what do you have?
Old Jul 26, 2016 | 11:43 AM
pmr2000's Avatar
pmr2000
Did the glovebox sticker with options come later?
Old Jul 26, 2016 | 11:52 AM
jackthelad's Avatar
jackthelad
Yes, they swapped the sticker over to the glovebox at some point fairly early on in the C5's life.
Old Jul 26, 2016 | 12:23 PM
Millennium FRC's Avatar
Millennium FRC
Just look for the power steering cooler. Dead give away.
Old Jul 26, 2016 | 12:35 PM
FGVette's Avatar
FGVette
The car has Z51 listed on its codes sticker and it looks like it has a separate cooler of some kind (long and narrow). I got to go with its a 1998 Z51 Coupe.
Now I just hope that the Brake Rotor Hub Covers I just bought from Ecklers (Z51, black) fit the car. Are the Z51 rotors of that year different than the standard rotors? Hmm.
To Do i have a Z51
Old Jul 26, 2016 | 01:03 PM
Rob 02's Avatar
Rob 02
The C5 Z51 just had slotted rotors and better pads. You should have no trouble.
Old Jul 26, 2016 | 01:16 PM
Bill Vett's Avatar
Bill Vett
No, not true. No slotted rotors.
Old Jul 26, 2016 | 01:29 PM
Rob 02's Avatar
Rob 02
Thanks for the correction. I was thinking of a special 50th anniversary or something.
