[Z06] Intersting Dyno Numbers....
Since my last visit to MTI, I added only the Borla Stinger Exh. When they baselined it again on Monday Am, it made 405/402!!! So I picked up 20 Hp and 22 Tq with just this exh??? I have about 3000 more miles on it now and I am sure that accounts for some of it, but I am still pretty happy. Can't wait for the numbers later in the week with the heads on!!! Hey this would be a great advertisement for Borla!
Les
I would contribute some of the gain to PCM relearn. If you were running the stock exhaust, I would also contribute the free flowing (read: zero restriction) of the Borla's as well. Nice numbers never the less. :cheers: :cool: :cheers:
The cam is the MTI C1 and the specs are as follows:
Dur: 222/222 Lift: 566/566 LSA: 112
Just because it was programmed, doesn't mean it had relearned. These PCM's are always adjusting, and I can guarantee you, you picked up some from the relearn. A good example of the relearn, came from John Page at 21st Century Muscle Cars (the new LPE shop in Dallas). They installed a Blackwing on an '02 Z06, did before & after dyno, and gained 6 rwhp. After a weeks worth of driving, they dynoed again, and it gained another 4 rwhp. You have LTFT (long term fuel trim), which can only be relearned from an extended period of driving. They are set from the factory for the stock application, and any modifications will cause them to run incorrectly until they have properly relearned. Sorry to be long winded, but the PCM does have to relearn for maximum gains, and not just for 5 minutes. :cheers:
[Modified by MillenniumVette, 9:33 AM 9/12/2002]
But it sounds like you have a higher lift cam which may benefit more from the less restrictive Borlas than a bone stock engine... Does anyone have numbers on the Borlas on a bone stock 02/03 Z06? Do the Cats have to go bye bye with the Borlas? Please excuse the ignorance on this point.
I do agree with the PCM re-learning theory. :cheers:
If the PCM was properly programmed than the fuel trims should be somewhere near zero, and definitely less than +5% after driving around for 100 miles or so. This should not have a major impact on his WOT power.
The only situation I can picture where a relearn would cause a pretty big power gain would be if the PCM programming was really off and the car was running very lean closed loop and WOT. The relearn would fatten things up and bring it back closer to where it should be. Looking at another possibility, if the PCM programming was causing a very rich situation a relearn would lean out closed loop but it would not help at WOT because the PCM will not lean out WOT and risk detonation or burned cats. The PCM will never lean the WOT Power Enrichment tables. This would leave you with a rich WOT mixture even after the relearn. Again, if the PCM was programmed properly none of this should be an issue. The power difference after a relearn should not be all that much. If it is then your programming is off.
The power difference should be coming from the exhaust change. As far as the BlackWing example goes, something sounds off there. Most stock cars with just a BlackWing eventually end up running with fairly high LTFT values after a relearn. This can cause an overly rich condition at WOT, which usually causes a loss of some power. I am guessing that his 4 HP gain was caused by dynoing the car on a different day with different weather, different correction values, or even different gas.
Every car can be a bit different so YMMV.
Also, my point was not that "ALL" the gains were from PCM relearn (see earlier post above). I am saying part of the gains were from PCM, but most were due to the less restrictive properties of the exhaust, essentially with no mufflers.
Dyno again in a few weeks, and see what you're at. :cheers:
The only way to see what is actually happening is to scan the car with an ODBII scan tool after logging about 100 miles, along with checking the WOT ratio with a wideband.
:cheers:
B1 221 221 .558 .558 114
T1 221 221 .558 .558 112
C1 222 222 .566 .566 112
C2 224 224 .581 .581 112
X1 230 227 .591 .571 112
R1* 232 237 .560 .560 114
S1* 244 244 .612 .612 112
Nice numbers. How is the idle? I have heard they are making 440-450 with the X1. But I haven't heard either the C1 or the X1 at idle. Also, I wonder if they will pass emissions...
Are your cats off?
i wonder what mine is doing now since its been a couple months :eek:
hopefully i should be over the 400 mark since ive got a little more aggressive (C2) cam.
even though youll beat me, i still wanna get a run in ! !
thanks
