[Z06] Need help doing a a4 swap
Was up guys I need some help on Wat am about to do to my 2001 c5 is a m6 so I'm swapping it to a a4 so my question is how do I make that a4 or m6 tranny harness work Wat are some of the stuff I gotta change an i kno I gotta flash my ecu this are some of the parts I have
Pedals
Flex plate
Bellhousing
Torque tube wit lines
Seal plate from trans to diff
Trans / harness
Shifter an cable
Aftermarket torque converter
I have all bolts an brackets
Is pretty much all bolt on but I was reading I have to extend the trans harness or add wires to it to reach the ecu I'm confused am sure someone has done this before so can I get some feed back
Pedals
Flex plate
Bellhousing
Trans / harness
Shifter an cable
Pedals
Flex plate
Bellhousing
Trans / harness
Shifter an cable
Pedals
Flex plate
Bellhousing
Trans / harness
Shifter an cable
