2000 Fuel pump / sender units
Old Aug 4, 2016 | 09:44 PM
rdb's Avatar
rdb
Default 2000 Fuel pump / sender units
Believe it or not I can't seem to find out if my 2000 has fuel pumps/guage sender in "both" tanks. I have the famous fuel guage problem (goes to 0 randomly). One article said I have sender in left tank only. Othes say I need to drop both tanks. Can someone point me in the right direction please. (I've tried the easy fix of Techron but only works "sometimes)
Bob
Old Aug 4, 2016 | 10:18 PM
JR-01's Avatar
JR-01
Are you running Shell or Chevron gas exclusively? I have not had the problem again since I started using Shell V-power gas.
Old Aug 5, 2016 | 12:01 AM
foggy's Avatar
foggy
TECHRON
use the black bottle, not the new cheaper grey bottle.
I use it 3 times a year...
Had the problem about 11 years ago.. Never an issue since.
Run the bigger bottle for about - 2 to 3 tanks in a row.
Your problem will probably be solved
Old Aug 5, 2016 | 01:24 AM
LoneStarFRC's Avatar
LoneStarFRC
Yer getting good advice here and btw, if you DO need or decide to replace a sender or pump, you do NOT need to drop your tank. Either of them.
HTH
Old Aug 5, 2016 | 11:02 AM
3sACROWD's Avatar
3sACROWD
I agree with the above. If you can change your tires, you have enough skill to replace the units if necessary. Depending on how fast you move, the job will take 2-4 hours. Try the other stuff first.
To 2000 Fuel pump / sender units
