Service Column Lock Issue still
Old Aug 7, 2016 | 06:09 PM
Hydeios's Avatar
Hydeios
Cruising
Default Service Column Lock Issue still
First of all, this will be My first post and I apologize if I bring up the same thing that has been discussed in the past. I have seen several post on the dreaded Service Column Lock and the recall that was done. I recently purchased a C5 1999 with Automatic Trans. The A/C blew Hot on Driver Side/Cold on Passenger. I took it to the shop and got it repaired. Now the problem, the condensation drain was plugged and after running the A/C, the passenger side floor board got soaked and we know that the BCM and a Fuse Box is located there. Shortly after this happened, I started getting the Service Column Lock message and did not know what to do. I researched on the Internet and found out about the Recall so I went to the local Dealership and talked to them. I know the Recall had not been done because My steering wheel still locked. I was told that the Recall had long been ended and so I researched a little more and found out about the LMC5 bypass. I purchased one thinking it would be the miracle cure but it did not fix it. I also read that low Voltage is usually the case if that does not fix it. My battery seemed good but I was frustrated and so I bought a New Battery trying to see if that helped and still getting the dreaded Message. I have cleaned the BCM with Alcohol and Q tips, avoiding any static and it did not fix it. I have ordered a BCM with the same Serv # and was told to do the RELEARN when I get it. My question is, If the BCM does not fix it, where would I go from there? Unfortunately I am not a Mechanic and only limited knowledge of Cars and almost none on the Electronics. Thanks for any Advice
Old Aug 7, 2016 | 07:23 PM
RoninC5's Avatar
RoninC5
8Vette7 makes a few good points and he knows what he is talking about... The LMC5 product is very reliable with a heck of a success rate and equally great support. However with water in the mix, anything may be possible. You'll get some great feedback here....BTW- My dealer offered to do the recall (as mentioned they have to) but the LMC5 is the real solution today....
Old Aug 7, 2016 | 09:49 PM
friou's Avatar
friou
I'd start with calling the vendor, they have a heck of a reputation for helping folks out. Then go from there if necessary. Best wishes!
Old Aug 7, 2016 | 10:43 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Old Aug 8, 2016 | 07:19 AM
tmirisola's Avatar
tmirisola
Old Aug 8, 2016 | 11:43 AM
Hydeios's Avatar
Hydeios
Cruising
I think my comments were taken wrong and apologize. All of you are correct, I spoke with the people I got the LMC5 from several times and You all are Right, I have nothing but Great Things to Say about Them and Their Customer Service. Their Tech Rep and I spent several Phone Calls trying to trace the issue down. They are continuing to Help Me also. All I was trying to find out was if anyone may Know of ANYTHING ELSE that could be the problem if The BCM does not fix it. THIS WAS NOT TO BASH THE LMC5, you can rest easy. Secondly, I did not come here until Now because They were working with Me and are Continuing to work with Me. All I really wanted to Know is what other Parts or Issues could be the problem, I really feel it is going to be a Wet Issue and hope the BCM fixes it. As far as what the Problem is I thought I explained it but guess not. I did get the Column Unlocked with another Item I purchased with the LMC5 and so Yes, the Column is Unlocked at this time, the Relay has been Disconnected, All fuses are Good with good Voltage tested with Multi Meter, but what other issue can I say, The car will Crank and The Fuel shuts off due to the Message. I do Appreciate the Replies but this was in No Way trying to put down the product.
Old Aug 8, 2016 | 11:58 AM
rrwirsi's Avatar
rrwirsi
Congratulations on buying your Vette and welcome to the forum. The forum will help you understand, identify, and repair stuff that breaks on the C5. Some of the members comments may get crusty as you found in some of the replies to your issue. But, mostly done in jest.
After the BCM install, please update the post. It will help others that experience the same issue.
Old Aug 8, 2016 | 12:05 PM
Hydeios's Avatar
Hydeios
Cruising
I sure will. I hope it will be in Today or Tomorrow and will update after install and Relearn is done. As far as the Replies, I understand where most come from and appreciate any and all info.
Old Aug 8, 2016 | 12:08 PM
Phanni's Avatar
Phanni
A weak battery can also give similar problems.
Old Aug 8, 2016 | 12:14 PM
Hydeios's Avatar
Hydeios
Cruising
Originally Posted by 8VETTE7
First of all you were pretty nieve to accept that a NHTSA safety recall even has an expiration. It DOES NOT. You can contact NHTSA to verify that fact. A dealer may try (succeed in your case) to getting rid of a customer by saying that but in fact they MUST service the car no matter how old the car is. In this case I would personally NOT let the dealer touch the car. JMHO. They will find a way to charge you for something that should be free of charge. Additionally the GM recall Service is NOT now nor has it ever been a permanent solution to the column lock symptoms.
Second you need to explain more about exactly what is happening after you installed the LMC5. Is the column still locked?? Are you getting some other symptoms related to column lock?? If so be specific in exactly what that is. We can't guess.
Third, when you were unable to clear the problem with the LMC5 why did you NOT call the vendor??? They are a very dedicated company with customer service second to NONE.
Lastly if you are not mechanically or electrically capable why did you wait so long and spend so much money before coming here???????????????
I do agree, call Me NIEVE but I went to a VERY WELL KNOWN and I thought WELL RESPECTED dealership in My Area. They looked up the Recall with My VIN# and told me Dates of Start and End. It puzzled Me that a Safety Issue would even end so I will look into that More. As far as the LMC5, I have nothing but Praise and Great things to say about the Company and Their Service. I Have spoke to them several times and They are working with Me still. Thank You for Your Info. I also posted another Thread explaining a little More.
Old Aug 8, 2016 | 12:22 PM
Hydeios's Avatar
Hydeios
Cruising
I checked My original Battery and was getting 12.55 to 12.6+ Volts with a volt meter but went ahead and purchased another Brand New battery and got the same results, SERVICE COLUMN LOCK. I have other things I can use the old battery in So Not a Waste of Money. Thanks for the Info.
Old Aug 8, 2016 | 12:27 PM
Hydeios's Avatar
Hydeios
Cruising
I do agree, Sorry I did not Mention that I had spoke to them on the Phone several times and that They were continuing to help Me. You are Right, Very Good Customer Service
Old Aug 8, 2016 | 01:32 PM
Hydeios's Avatar
Hydeios
Cruising
You did say the car is an automatic and you further have said that the column physically locked at one point. This tells me that the recall service was NOT performed on the car by GM or if it was performed that it was NOT done correctly. On the 97 - 2000 automatics a required step was to replace the column lock ring with a smaller diameter lock ring that physically prevents the column from locking. Since your column physically locked at one point the full size lock ring is still in place.
The LMC5 install requires that the column be physically unlocked and it sounds like you accomplished that probably with the unlocker tool. So at this point I would NOT bother with getting the Stealership to perform the recall service since they will certainly cause additional complications if not expense to your situation.
All this is moot at this point because it seems that the problem you are experiencing is the fuel shutoff when you attempt to drive the car. Is this correct???
If yes then there is a solution that can be done to the car to stop this from happening if a replacement BCM does not correct the symptom. As stated above, the BCM getting wet seriously complicates things since it is the BCM that completely controls the column lock system. Possibly a replacement BCM will function correctly.
You can find a tuner with either EFI Live or HP Tuners tuning software and have the fuel shutoff speed set to a high number such as 200 or 255MPH. This speed is stored in the PCM and NOT the BCM. This fools the system since even if the BCM requests the "enabling" of the fuel shutoff by the PCM, the PCM uses the stored speed to determine when to shut off fuel. 200 or 255mph should meet your need I suspect.
Yes the column was locked and I used the Unlocker to Unlock it so I agree that the recall was not done or poorly done. Either way I like the Idea of the LMC5 Fix. The car does crank and shuts off around 1 or 2mph. I have seen where the shutoff speed can be raised by getting it reprogrammed but would there be anyway to clear the Service Column Lock message if the shutoff was raised. Thanks for any Info
Old Aug 12, 2016 | 06:37 PM
Hydeios's Avatar
Hydeios
Cruising
Here is where I am at now. The BCM came in, installed it and did the relearn between the BCM and PCM. Service Column Lock went away but got Shocks Inoperative, Maximum Speed 80mph, Service Drivetrain Soon. Felt like We were making Progress as now the car could at least be Driven. I know that different suspension packages were available and contacted the place I got the BCM from. They advised Me that it was a very simple fix and just needed someone that had a Tech II to go in and change the setting. I took it to a shop that had a Tech II this morning and They hooked it up but was unable to access the program needed to Delete the option. While still connected, the Service Column Lock message appeared again along with the other messages still present. The strange thing is that I was able to drive it this time with the Service Column Lock where as in the past, The fuel was shut off at 1 to 2MPH. I was told by a Friend that the Shop I carried it to may not have all the necessary programs for the Tech II. I have a call out to a Speed Shop approx. 30 miles away and waiting to hear back from them. I will Update as We progress with it.
Old Aug 12, 2016 | 06:42 PM
Hydeios's Avatar
Hydeios
Cruising
No. The raising of the fuel shutoff is just making the car driveable. The "Service Column Lock" message and or the "Pull Key and Wait....." messages are generated by the BCM because it thinks the column lock system is NOT working correctly. There may be due to problems internal to the BCM from it getting wet or there may be external issues with the wiring or LMC5 install that cause the BCM to think the system is not working.
The only thing you can do to check the external causes is check and double check the LMC5 install and the wiring to the Column Lock Relay and the relay itself for the Column Lock Relay if it is still installed.
Since you mentioned that you have ordered a replacement BCM and plan to install it, you should check the wiper well udders on the car as well as the AC Condensate drain if you have not already done so. Would be a horrible thing to install a new BCM and then have it get wet because of either washing the car or driving in rain.
Here is a link to a thread that discusses these issues with pictures:
http://forums.corvetteforum.com/c5-t...ak-checks.html
Thank You, I did clean Three on the Driver's side and One on the passenger side behind the battery. I am not sure if the Passenger Side one and the Condensation Drain are the same but a Friend of mine crawled under the car and was able to clean out a drain that now allows the A/C to drain while running. He had done it before I found the Udder behind the battery so not sure if that was the one he cleaned but it was clean compared to the other Three.
Old Aug 12, 2016 | 07:07 PM
Smoken1's Avatar
Smoken1
Interesting I had no problem deleting my F45 stuff
Old Aug 12, 2016 | 09:37 PM
Mickeyrx70's Avatar
Mickeyrx70
Old Aug 13, 2016 | 11:11 AM
Hydeios's Avatar
Hydeios
Cruising
The "Shocks Inoperative..... " is clearly because the BCM you received has the RPO for F45 configured into it. Here is a link to the steps necessary with a TECH II to clear that RPO. The procedure referrs to the F55 RPO which is the option for the 2003 - 2004 C5's but the steps to deleting the F45 are EXACTLY the same as for the F55:
https://www.corvetteforum.com/forums...-and-25-a.html
Anyones guess what the message about the "Service Column Lock " was all about. It could easily be the result of leaving the key in the ignition while the tech was attempting to delete the F45 RPO and then you starting the car without first removing the key.
STRONGLY recommend that you get an LMC5 and install it ASAP so you never have to deal with the column lock issue again!!! SAVE the install instructions after the install in case you start to get the "PULL KEY......" message after the LMC5 install. On page 2 of the install instructions is a procedure for doing the "brown wire" mod that will prevent that message. Some BCM's encounter timing relayed problems that require the brown wire mod.
The person that told you the TECH II needed additional programs does not know what he is talking about!!!! The person with the Tech II obviously does NOT know how to use it. There is NO SEPARATE program to be able to delete RPO's. The Tech simply is unfamiliar with the tool and lacked any idea of how to accomplish the F45 delete.
If you are unable to find someone else with a TECH II that does know how to use it, take the above instructions back to the first TECH and provide him with the proper steps.. He should NOT attempt to take any shortcuts. Follow the steps to the letter.......
I really appreciate the info. I have found another shop that said they have one and I am suppose to contact Them at the first of next week. I am going to print out the directions and carry them with me for sure. As far as the Service Column Lock, I have already installed a LMC5. After we try to reset the BCM, if I continue to get the message I am going to Check and Recheck again the install. I have already but will do it again. The company has sent me another LMC5 to try just to rule out a VERY RARE bad one. I will update
To Service Column Lock Issue still
