Lmc5
Old Aug 12, 2016 | 09:40 AM
collec_96's Avatar
collec_96
Default Lmc5
I purchased this and installed it the car works now ... kind of. I still get the message "Pull key wait 10 seconds" car will not run shuts off at 2 mph however, if I do as instructed car works fine. Have I missed a step with the installation of the LMC5? Read through the instructions again and haven't found a misstep.
Old Aug 12, 2016 | 09:57 AM
Velocity_Vette's Avatar
Velocity_Vette
Look up the "LMC5 Brown Wire Mod". Richard at ComplianceParts can help you further if you don't understand the steps. It often eliminates the "Pull Key" message with LMC5 installed.
Old Aug 12, 2016 | 10:17 AM
RoninC5's Avatar
RoninC5
Agree with velocity. Many cars respond a bit different and if you are getting the Pull key frequently-call Richard. The Brn wire mod may help you out. I still get the pull key as well but not often. It has been a couple months now..
Old Aug 12, 2016 | 10:31 AM
caddman11's Avatar
caddman11
I had the brown wire issue with my 2001; I watched the Youtube instead of reading the instructions and the brown wire issue is not included on the Youtube.
Old Aug 12, 2016 | 10:48 AM
royal flush's Avatar
royal flush
You will have to do the BWMod--its easy and it works--no more "pull key' message--lmc5 brown wire controls the timing issue with the BCM--if your unit doesnt have a brown wire, than you have the old version and will need the 5 wire unit--keep us informed--
Old Aug 12, 2016 | 12:12 PM
collec_96's Avatar
collec_96
Thanks guys. I do have the brown wire and will connect it this evening. One more question, will this also eliminate the 2 mph shut off?
Old Aug 12, 2016 | 12:25 PM
v6turbo87's Avatar
v6turbo87
Yes it will.
Old Aug 12, 2016 | 12:30 PM
caddman11's Avatar
caddman11
Did for me.
Old Aug 12, 2016 | 01:01 PM
royal flush
With BW mod--You wont see any messages again-thus no fuel-cutoff-You dont need a tuner to raise mph-
Old Aug 13, 2016 | 04:10 PM
royal flush
Would be great if people who post--have problems--told what to do--would come back with results?
Old Aug 13, 2016 | 04:45 PM
calvins's Avatar
calvins
Oldtimer
This subject has been beaten to death in this forum. A simple search is all that's required.
Old Aug 13, 2016 | 04:55 PM
royal flush
Sorry-- I looked up-beaten to death threads--nothing came up--would you be so kind as to find all the threads and pass on to me!
Old Aug 13, 2016 | 09:23 PM
calvins's Avatar
calvins
Oldtimer
I think you'd have no problem finding them if you'd simply try to help yourself.
Old Aug 15, 2016 | 07:27 PM
collec_96's Avatar
collec_96
I thought I did let you all know how your help and suggestions helped me but here ya go...the LMC5 worked great, no problems now, car runs great! Thanks again for all your help....
To Lmc5
