[Z06] LS3 swap underway......
Old Oct 27, 2016 | 08:36 PM
  #101
tommypenguin's Avatar
tommypenguin
Did you use the stock sized hinson motor mounts or the lowered by 3/8" ones?
Old Oct 27, 2016 | 08:39 PM
  #102
turboffr's Avatar
turboffr
St. Jude Donor '10
Stock. I know the lowered ones are recommended when running a FAST intake but with the LS3 I have no plans on adding a FAST.
Old Oct 27, 2016 | 09:04 PM
  #103
sk61380's Avatar
sk61380
I will be running the lowered ones in my ls3 swap. I have them in now with my ls1, I doubt that there will be any issues with running the lower ones, since the engines are basically the same dimensions, but I'll find out.
Starting on my swap on Nov 28th.
Old Dec 23, 2017 | 10:12 PM
  #104
nsogiba's Avatar
nsogiba
Just wanted to bump this thread to thank OP for all the great detail of parts required for the swap. I'm in the process of collecting parts for my own project and this thread has been a great resource.
Old Dec 24, 2017 | 02:37 PM
  #105
jpb1978's Avatar
jpb1978
Photobucket sucks!!!!!
Old Mar 3, 2018 | 07:53 AM
  #106
Mike94ZLT1's Avatar
Mike94ZLT1
Originally Posted by turboffr
UPDATE:
I've driven the car approx 250 miles now ...
For those curious about the Lingenfelter converter box, it does was its supposed to do and I haven't had any issues with it.
How about another update on this!
Old Mar 3, 2018 | 07:58 AM
  #107
turboffr's Avatar
turboffr
St. Jude Donor '10
Still working flawlessly. I actually just sold the vette on Thursday. On to the next project
Old Mar 5, 2018 | 11:53 AM
  #108
nsogiba's Avatar
nsogiba
Did you get bored of the car? Just curious.
Also, before you turbo'd the car, what intake setup were you running? Cartridge LS7 MAF?
Old Mar 5, 2018 | 11:57 AM
  #109
turboffr's Avatar
turboffr
St. Jude Donor '10
No not bored. I'm building something else and can't keep them all. It was a great street car.
Before turbo I was using the factory Z06 MAF. Tuned just fine with HP Tuners.
Old Mar 5, 2018 | 12:24 PM
  #110
Drewster67's Avatar
Drewster67
Love my C5 with the LS3 but I too am thinking about selling it and going to the next project. In a little over a year - I have put less than 4K miles on it since the new dewitts rad,new mantic ER2 clutch and new crate motor swap. Such a fun, fast car.
Old Mar 5, 2018 | 01:23 PM
  #111
nsogiba's Avatar
nsogiba
What are you guys thinking about building next?
Were you running the stock Z06 MAF too? Think the stock LS1 MAF is too restrictive? (78mm)
Old Mar 6, 2018 | 02:41 PM
  #112
Drewster67's Avatar
Drewster67
You cant run the stock LS6 TB with a LS3 - You will need to source a LS2 Silver Blade TB .
I'm looking for a 996 Twin Turbo.
Old Mar 6, 2018 | 02:48 PM
  #113
turboffr's Avatar
turboffr
St. Jude Donor '10
Yes, you do need the silver blade throttle body. The LS6 Z06 MAF works just fine with the LS3. Not sure why you stated it doesn't work.
Old Mar 6, 2018 | 03:22 PM
  #114
nsogiba's Avatar
nsogiba
Yup, I think he maybe made a typo. I am going to be using a silver blade LS2 GTO throttle body, LS3 intake manifold, and the Z06 MAF (thanks again for that Mike).
Gotta order the 3 pin to 5 pin MAF adapter tonight...
Old Mar 6, 2018 | 03:41 PM
  #115
Drewster67's Avatar
Drewster67
yes sir - thinking TB but typed MAF .. lol
Old May 27, 2018 | 04:09 AM
  #116
C6-LS2-MN6's Avatar
C6-LS2-MN6
why can't you use the LS3 TB that comes with the new long block?
Old May 27, 2018 | 04:42 AM
  #117
turboffr's Avatar
turboffr
St. Jude Donor '10
It opens in the opposite direction. Not compatible with your computer/TAC module. LS2 silver blade is compatible and is same dimension as LS3
To LS3 swap underway......
Old Jun 17, 2018 | 06:12 PM
  #118
Boozshey's Avatar
Boozshey
Did you ever put it on the Dyno? Just curious what sort of number it did with the combo you selected.
Old Jun 17, 2018 | 06:43 PM
  #119
turboffr's Avatar
turboffr
St. Jude Donor '10
801rwhp with a turbo
Old Apr 24, 2020 | 01:46 AM
  #120
Temps_c5's Avatar
Temps_c5
Hello probably a dumb question but does all this also apply to a ls7 swap wet sump I figured it would
