LCM5 question
Old Aug 15, 2016 | 04:53 PM
kcobain147's Avatar
kcobain147
2017 C5 of the Year Finalist
Default LCM5 question
Finally got the thing in after two attempts. The fact I needed to pull fuse 23 was missed...forcing me to put the stock wiring back in, and start over outta fear of locking the column. After some..confusion on when to pull the fuse, got it, no issues. Installed, no warnings, no problems.
Question is the relay. I have it. I pulled the green pin, pushed the tab, the thing was not interested whatsoever in coming out. Like. At all. 15 min i said f*** it and left it in fear of breaking it.
Question I have - is it required to pull it, or optional. It looked optional, but wanted to confirm.
Thanks in advance.
Old Aug 15, 2016 | 05:05 PM
Kmcoldcars's Avatar
Kmcoldcars
I just did the LCM5 on my car. To get the relay out I pulled the locking pin and then had to depress the locking tab on the side of the connector using a screwdriver and really pull on the relay (and its wires) to get the relay out. It took some patience but I was able to do it. That was the hardest part of the whole install.
Old Aug 15, 2016 | 05:07 PM
kcobain147's Avatar
kcobain147
Yea - i didn't wanna use that much force. Hence the question on if it's actually required or not. Pulling on wires is never good..i'm fine leaving it there if nothing will malfunction.
Old Aug 15, 2016 | 05:12 PM
royal flush's Avatar
royal flush
TRY again--Richard said its part of the whole gm locking column ****--i used a screwdriver and just pulled hard--it will come apart-
Old Aug 15, 2016 | 05:14 PM
Kmcoldcars's Avatar
Kmcoldcars
I figured that since it is to be left disconnected I could not hurt anything by pulling on the wires. They gave me the best way to pull it as it is very hard to get a good grip on the relay itself.
I believe it should not hurt anything to leave it connected, at least until the relay malfunctions and causes problems.
Old Aug 15, 2016 | 05:37 PM
kcobain147's Avatar
kcobain147
Figured when in doubt, call the person who'd know the best. Richard basically said it's future proofing that relay crapping out. Won't hurt to leave it in till i get more time/ambition/patience to try to get it out, however it's advisable to remove it at some point.
Old Aug 15, 2016 | 06:19 PM
royal flush
Same thing Richard told me--mine just wasnt that bad to get out---also there is a short video on you tube i watched--for now your doing fine-
Old Aug 15, 2016 | 06:59 PM
RoninC5's Avatar
RoninC5
Yep, similar story. Went with video vs the fine print. I got the fuse part but just spaced the relay. For now, it's still in there....
Old Aug 15, 2016 | 07:23 PM
Ducati Guy's Avatar
Ducati Guy
I did the relay. Used a small screwdriver between the relay and the piece that comes out. Just pried it apart.
To LCM5 question
