My windshield wipers are possessed
Old Aug 23, 2016 | 03:17 PM
Lucas456's Avatar
Lucas456
Default My windshield wipers are possessed
So last night it rained pretty hard like torrential down poor. Anyway this morning on the way to work my wipers took on a mind of their own. They would just wipe and wipe while i had it turned off. As of this afternoon they wont even come on. Is my wiper motor fucked? Anyone experienced something similar?
Old Aug 23, 2016 | 04:11 PM
Lucas456's Avatar
Lucas456
Holy crap, that goes way past my technical know how. How much do you think id get fucked if i took it to a stealership?
Old Aug 23, 2016 | 04:17 PM
BlackandTan2004's Avatar
BlackandTan2004
Not comfortable taking the battery out? Because that seems to be about it based on the link 8VETTE7 posted. I get you if you are out of your comfort zone, but it seems pretty cut and dry. Got a buddy or handy family member? If your wiper motor is fried then you will spending some quality time at the dealer anyway.
Old Aug 23, 2016 | 04:21 PM
Lucas456's Avatar
Lucas456
It says u gotta take floor boards and tires off. I have a few handy buddys i can ask though.
Old Aug 23, 2016 | 04:34 PM
BlackandTan2004
I believe that is just in regards to internal leaks. You are only concerned in the wiper motor which is on the drivers side so just look for the three udders referenced in the 4th & 5th pic only.
Old Aug 23, 2016 | 04:38 PM
Lucas456's Avatar
Lucas456
Sorry about the language.
Ok i need to re look at that post. On a 1-10 scale 1 being a yuppy from san fran cisco, and 10 being a the chief mechanical officer at chevrolet my mechanical know how is like a 3.
Old Aug 23, 2016 | 04:41 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Old Aug 23, 2016 | 05:46 PM
craig_vette's Avatar
craig_vette
You'll need to check/unclog your udders regardless but you may need a new motor now too.
There are 3 udders on the driver side. The front 2 are easy to get to but the third (a little further back) is a pain to reach. Nevertheless, it's reachable by hand and you should be able to get to it (just barely).
When you check the passenger side udder, be careful not to pull out the whole udder. Just disconnect and leave it be. Then use a hose to flush it out. You don't want to pull it all the way out b/c it's a pain to put back in place. All you have to do is remove the battery to get to it.
Old Aug 23, 2016 | 05:51 PM
Lucas456's Avatar
Lucas456
Ok thanks ill waych that video aftrr work and see if ill be abld to knock it out. So if i clear up the debtis the wipers should work? Or im still going to need a new motor?
Old Aug 23, 2016 | 09:08 PM
Oh 2 Fun's Avatar
Oh 2 Fun
I'm in the same boat as mine only work when I hit the switch once, or on the hyper speed mode.....no intermittent or regular. So I'm assuming it's the motor circuits, not the switch. Only way to tell (I think) is to expose the connection to the motor and test the wires for power.
Power present.....bad motor circuits
Power absent....bad stalk switch.
Old Aug 23, 2016 | 09:23 PM
Good luck getting this solved. Hope it does not involve having to replace the motor.
Old Aug 23, 2016 | 09:58 PM
garline14's Avatar
garline14
I just had this exact same problem 2 weeks ago. Car sat out in the rain all day at work and the wipers started coming on by themselves. Had to pull the fuse to get them to stop. My drain udders were clogged up pretty bad so chances are the water flooded the circuit board. I cleaned my udders and also cut the bottom of them so water and other trash can flow more freely through them. I also bought a remanufactured wiper motor from autozone for 55 dollars and now the wipers are back to normal. The wiper motor and circuit board are sold together as one. Its a fairly easy job to do urself. I actually took the motor out twice, once to clean the old motor and see if that would help(it didnt) and then again to install the new motor. Second time it only took about 30 to 45 minutes to take everything apart and reassemble. Its really not a difficult job to do. If u decide to do it urself, id recommend getting some penetrating blast to soak the wiper arm bolts in. U dont necessarily need a puller like some people use, i used penetrating blast as mentioned above and i was able to wiggle the arms free.
Here are 2 very helpful and detailed write ups
https://www.corvetteforum.com/forums/c5-tech/1715595-wiper-motor-removal-procedures.html
http://www.digitalcorvettes.com/forums/showthread.php?t=121213#/topics/121213?_k=ljlj5b
Old Aug 23, 2016 | 10:09 PM
Lucas456's Avatar
Lucas456
Ok so i called the buddys i know that are mechanically inclined and they pretty much responded they will never work on a corvette (these are Army mechanics) so chevrolet is charging me 115 bucks to diagnose exact issue the who knows what to repair.
Old Aug 24, 2016 | 12:00 AM
CindysC5's Avatar
CindysC5
Seriously Lucas?!?!?!? I'm a woman and could do that! C'mon, at least try!! Give yourself a little credit! We're not talking rebuilding a motor! You can do it!!!!
Old Aug 24, 2016 | 12:36 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Army mechanics from the first World War?
Corvette motor is one of the easiest to work on.
Old Aug 24, 2016 | 09:38 AM
Lucas456's Avatar
Lucas456
So they cant even look at it till next tuesday, im setting that up on purpose as a back up. This weekend im goingbto attet to fix it on my own but if i cant im taking it to chevy.
Old Aug 24, 2016 | 11:42 AM
craig_vette
Is it worth trying just the pulse board?
https://www.amazon.com/ACDelco-12367.../dp/B0013G03XO
To My windshield wipers are possessed
Old Aug 24, 2016 | 11:50 AM
pmr2000's Avatar
pmr2000
Easy fix compared to other Corvette woes, up on top, just take off wipers, remove the plastic tray held in by push pins, remove battery, clean out all the udders.
Wiper motor is also easy swap, calibration a little bit of a pain.
Old Aug 24, 2016 | 11:58 AM
garline14's Avatar
garline14
Usually thats the part that needs to be replaced. I dont think any local parts store will sell just the pulse board though.
Lucas456's Avatar
Lucas456
Oh cool, yeah ill try that, if it works ill cancel my appt with chevy
