Thanks. I will tackle this after I get the AC drain plug unclogged. Had to remove just about everything from the passenger side to dry things out. Blower and motor appear to be OK, other than being dirty and covered with surface oxidation.
Cheers
hmmmmmmmmm. passenger side got wet? Are we talking in the passenger foot wel? If so you do know that BCM computer is right behind the floor board. If it is wet in that area there is a good chance the BCM got wet and that is causing your problem.
