Re-foamed driver seat bottom
Old Aug 28, 2016 | 01:12 PM
caddman11's Avatar
caddman11
Default Re-foamed driver seat bottom
I'm a big guy and my drivers side sports seat was killing me, my butt ached after about a half hour of drive time. I didn't want to buy new seats and the leather was still in really good shape so I bought new bottom foam.
I read all the descriptions on how to accomplish my mission. When I got the seat apart (pretty easy) the wire Chevy calls springs had almost cut through the foam; no wonder it was killing me. I ended up using wire ties for the job and cut a piece of industrial carpet square to sit on top of the wire springs rubber side towards the new foam to keep the spring wires from cutting through again.
What a difference this makes. For about $80 with shipping and less than two hours work, you can have some comfort again.
Old Aug 28, 2016 | 01:57 PM
johnson-rod's Avatar
johnson-rod
When I replaced the driver's seat bottom foam it felt like a new car.
Old Aug 28, 2016 | 02:40 PM
Mickeyrx70's Avatar
Mickeyrx70
My experience too. I had to adjust my seat an inch or more lower to offset the new- found thickness. The new foam really improved the comfort.
Old Aug 28, 2016 | 02:41 PM
Rob 02's Avatar
Rob 02
Great to hear. I will be working on my interior soon and I will take a look at this.
Old Aug 28, 2016 | 02:46 PM
zachaeous's Avatar
zachaeous
I also added the seat rebuild kits from Southern Car Parts to both sides. I replaced the bottom seat foam only on the drivers side.
Old Aug 28, 2016 | 05:07 PM
El Paso Vette's Avatar
El Paso Vette
When I replaced my cushions in my C5 it WAS like the car was brand new. What a difference it makes.
Old Aug 28, 2016 | 05:13 PM
Rob 02's Avatar
Rob 02
Is there a difference in the kind/ quality of foam available in the aftermarket?
And the OP did mention spring wear.
This is all very informative. When I sit in my car it just doesn't feel right. I couldn't quite figure out why, but this thread nails it.
Old Aug 28, 2016 | 06:00 PM
danh52's Avatar
danh52
I first tried one of the seat foam kits from a forum vendor and in my case it made very minimal improvement. The outside bolster foam was shot. I just got done replacing the seat bottom foam and got mixed results.
Good: It did make an improvement in the feel of the stock sport seat. Total cost about $90 for the seat foam and $40 I think for the kit.
Bad: The seat still sucks as to support when cornering. I think I would have been better off spending money on a better seat. That's next on the mod list. Just have to decide on which seat to go with.
Old Aug 28, 2016 | 06:12 PM
Rob 02's Avatar
Rob 02
I like having all the electrical adjustments of the OE. I wonder how hard that is to transfer to an after market seat as a DIY.
Old Aug 28, 2016 | 06:14 PM
caddman11's Avatar
caddman11
I bought mine from Corvette Central, very close to me and pretty cheap shipping. Hard to tell exactly about foam from different places. Figuring the old foam is sliced up and brittle, the new foam seems a little softer. I had called another place that advertised firmer than stock, I just couldn't get them to return my calls.
Old Aug 28, 2016 | 09:57 PM
After so many years, no doubt that new seat foam made a huge difference.
To Re-foamed driver seat bottom
