Replace door speakers in My '99 ???
Old Aug 30, 2016 | 04:03 PM
SaxyVette's Avatar
SaxyVette
Default Replace door speakers in My '99 ???
My new to me '99 has the stock stereo and the speakers sound pretty blown out. Anybody replaced just the speakers?? are they BOSE ??
Old Aug 30, 2016 | 04:36 PM
GCG's Avatar
GCG
Without a doubt, the easiest and least expensive way to upgrade the system with the more bang for your buck is new speakers that can be bolted on in place of the factory ones, keeping the rest of the system intact.
OEM C5 Speaker Sizes:
-Front
Twiddler: 3.5"
Subwoofer: 8"
-Rear Twiddler
Coupe: 6.5"
FRC/Z06/Convertible: 5.25"
Give this a try, and then reassess to determine how far you want to go down this road :
Get 3.5" 2-way coaxial speakers to replace the doors' twiddlers and 2-way coaxials of the right size for the rear. Don't touch the OEM subwoofers.
Old Aug 30, 2016 | 08:31 PM
Mike94ZLT1's Avatar
Mike94ZLT1
...Or do it the right way and replace everything and be blown away at what you've been missing.
www.doubledmods.com
Old Aug 31, 2016 | 03:08 AM
SaxyVette's Avatar
SaxyVette
Mike that's a beautiful set up, something to put on the wish list..!!
Old Aug 31, 2016 | 07:54 AM
GCG's Avatar
GCG
Saxy, in Post #2 above, when I answered your original question I forgot to address a concern you had. No, you don't need or want Bose replacements
If money is tight, just get 2-way coaxials for the 4 twiddlers and you'll hear the difference
Old Aug 31, 2016 | 09:54 AM
Chicago1's Avatar
Chicago1
I replaced all mine with JL and to be honest they sound like ****. Maybe I need an amp?
Old Aug 31, 2016 | 11:21 AM
GCG's Avatar
GCG
Which JLs you used? Were they 2-way coax speakers?
Old Aug 31, 2016 | 11:46 AM
SaxyVette's Avatar
SaxyVette
Good info please keep posting
Old Aug 31, 2016 | 01:04 PM
Carl Timonen's Avatar
Carl Timonen
I just went through this. I replaced the h/u with a Kenwood single din (cheap) and the speakers with the JL Audio along with the JL Audio 400w amp. The door speakers are the components and the back are the coax. Sounds so much better than the stock set up. In hind sight, wish I would've went double din, but the cost was prohibitive at the time. Wanted the money for suspension upgrades.
The main thing I wanted was bt capability and able to play my playlist.
Old Aug 31, 2016 | 05:10 PM
73Corvette's Avatar
73Corvette
I used Kicker replacements... if, I were doing it again I would get Alpines....the Kickers were a BIG improvement...
Old Sep 1, 2016 | 09:13 AM
Mike94ZLT1's Avatar
Mike94ZLT1
Are you using the factory head unit and wiring?
Old Sep 1, 2016 | 11:16 AM
DollysC5's Avatar
DollysC5
6th Gear
yes there definitely Bose !!! Damn I blew? I would upgrade the whole system then LOL
Old Sep 1, 2016 | 01:53 PM
SaxyVette's Avatar
SaxyVette
I did not do the damage I just got my '99 vert and the speakers just don't sound very good. I was very satisfied with the stock Bose in my previous '99 actually sounded pretty good.
Old Sep 1, 2016 | 03:15 PM
Sinister-one's Avatar
Sinister-one
-Front
Twiddler: 3.5"
Subwoofer: 8"
-Rear Twiddler
Coupe: 6.5"
Can you guys provide model numbers so I can look them up on Cruthchfield ?
PLEASE.....
Old Sep 1, 2016 | 07:13 PM
73Corvette's Avatar
73Corvette
I believe Dennis@ Double D Mods sells them as a kit... might contact him and see if he's still putting together a package like this
Old Sep 3, 2016 | 12:02 AM
GCG's Avatar
GCG
PLEASE.....
You will need to further verify fitment, but a quick search produced this:
JL Audio Evolution™ C2 Series 2-way car speakers
  • C2-350X (3-1/2")
  • C2-525X (5-1/4")
  • C2-650X (6-1/2")
Not only they are from the same manufacturer, but they all belong to the same line. This should reasonably assure you they have the same timbre.
They can be found in Amazon or Crutchfield
Old Sep 3, 2016 | 08:45 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Hit the dealer and make sure you get a few of the plastic pins that hold the door panel to the door. You WILL break some!
I bought the speaker upgrade kit from Dennis at DoubleD.
Good Luck!
To Replace door speakers in My '99 ???
Old Sep 6, 2016 | 01:47 PM
Chicago1's Avatar
Chicago1
The cx series I believe yes they are coax but let me check tonight and double check
No Pioneer double din that I got from Dennis
Old Sep 6, 2016 | 03:30 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Jump to post #48 to see what I did...
https://www.corvetteforum.com/forums...project-3.html
...best of luck!
Old Sep 6, 2016 | 04:24 PM
sbadd99's Avatar
sbadd99
I put in 3 way Focal speakers and a Pioneer head unit years ago dumping the Bose, the speakers took some work the rest was simple, very happy with the sound quality.
