Ac not cooling
Old Sep 1, 2016 | 09:58 PM
moekluse's Avatar
moekluse
Default Ac not cooling
So ac is blowing but not cool. System is charged with refrigerant, when I hit the button to turn the compressor on, it dosent light up, is there a fuse I should check for? Is there a sensor I can check? How can I tell if the compressor is bad. Thanks
Old Sep 1, 2016 | 10:29 PM
JR-01's Avatar
JR-01
Any codes?
Old Sep 2, 2016 | 12:00 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
This may help you !!!
File Type: docx
Old Sep 2, 2016 | 12:48 PM
moekluse's Avatar
moekluse
Originally Posted by 8VETTE7
Fuse #24 and relay #34 in the engine compartment fuse box.
What does the exterior temp show on the dash?? If that sensor is bad it affects the operation of the AC.
I will check when I get home as I do not daily drive it
Old Sep 2, 2016 | 12:49 PM
moekluse's Avatar
moekluse
Thank you
moekluse's Avatar
moekluse
Originally Posted by JR-01
Any codes?
A few codes but none to do with ac. When I get home I'll check the dic and list then
Old Sep 2, 2016 | 07:12 PM
c5z06.O's Avatar
c5z06.O
Default Ac
Crazy idea. But my ac was workinh fine. I had a coolant leak. Pressure was not as its suppose to be. I lost my ac. Once i replaced the reservoir the ac started working again. Like i said. It sounds crazy but i have no idea if the pressure or leak affects the ac. Someone correct me please.
Old Sep 23, 2016 | 09:47 AM
moekluse's Avatar
moekluse
I know there is freon in the system, but I don't hear the compressor, is there a way to directly jump the compressor so I can make sure it's not bad, can I just apply 12v to input or is there a special way to jump it
Old Sep 23, 2016 | 09:53 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
post #3 doc
Old Sep 23, 2016 | 10:44 AM
FX VETTE's Avatar
FX VETTE
It would be readable by a much larger audience if it was a PDF file instead of a MS Word .docX file.
PDF version attached
Attachment 48021018
Old Sep 23, 2016 | 11:39 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Two suggestions for the item in post #3:
1) It would be readable by a much larger audience if it was a PDF file instead of a MS Word .docX file.
2) Would be much more understandable if it included a wiring diagram for the HVAC system so the referenced "Points" and "Circuit numbers" could be followed.
JMHO
I used it for the same reason on my vette and thought it was very easy to follow, yet as a experienced mech sometimes I take a lot for granted !!!!! Thanks Chuck !!!
Old Sep 24, 2016 | 12:09 PM
moekluse's Avatar
moekluse
Is there an outer temp sensor with the manual ac? Is there a way look at it from dic? I checked the fuse and relay and they were fine.
Old Sep 24, 2016 | 12:29 PM
moekluse's Avatar
moekluse
To Ac not cooling
