[Z06] Exhaust Tips Crooked
Old Sep 13, 2002 | 03:32 PM
ZO6Les's Avatar
ZO6Les
Default Exhaust Tips Crooked
A fellow Z06 owner (Nick) pointed out to me during the Biltmore cruise that my exhaust tips are crooked. I gave them a good look and he is right, the left two hang about a 1/2 inch lower than the right side.
Is this an easy adjustment I can do myself or is it dealership time?
Les
Old Sep 15, 2002 | 06:42 PM
levettegrl's Avatar
levettegrl
Cruise-In IV Veteran
Default Re: Exhaust Tips Crooked (ZO6Les)
you can do it yourself-just need to lift the rear to get around the sway bar, you will see the bolts to loosen so you can adjust them (18mm socket needed).
Old Sep 17, 2002 | 01:11 PM
CDHough's Avatar
CDHough
Cruise-In II Veteran
Default Re: Exhaust Tips Crooked (levettegrl)
When I was in for other service, I had the dealer align mine. They still were not perfectly even so I added some washers to the bracket holding the muffler in place to lower the left side.
- Charley
Old Sep 17, 2002 | 04:18 PM
CALVette's Avatar
CALVette
Cruise-In V Veteran
Default Re: Exhaust Tips Crooked (CDHough)
- Charley
I also place the washers on the bracket, it was however a little tricky getting two stacks of washers to stay in place.
Old Sep 17, 2002 | 04:38 PM
CDHough's Avatar
CDHough
Default Re: Exhaust Tips Crooked (CALVette)
It was tricky for me too. It does seem to work fine.
- Charley
Old Sep 20, 2002 | 01:22 PM
Mark S.'s Avatar
Mark S.
I slotted my washers using a dremel that way I didn't have to remove the bracket completely...lowered the bracket just enough and slid the washers into place ensuring the the slots overlapped.
Old Sep 20, 2002 | 01:36 PM
CDHough's Avatar
CDHough
Default Re: Exhaust Tips Crooked (Mark S.)
That sounds like it would make the installation easier. I was just concerned that the washers could back out over time.
- Charley
Old Sep 20, 2002 | 02:03 PM
Mark S.'s Avatar
Mark S.
Charles, so far after a year and half they seem to have held okay. I do check them periodically.
To Exhaust Tips Crooked
