Pre-Waxing Glaze
Old Sep 10, 2016 | 02:49 PM
Deluxe's Avatar
Deluxe
St. Jude Donor '06 thru '16,'22,'24
Default Pre-Waxing Glaze
Anyone try this?
I've finally retired my daily driver with over 120K miles in order to restore it to it's original awesome.
I picked up a bottle of Maguiars Pre-Polishing Glaze by accident.
* shrug * Let's see what it does.
I am pretty impressed. It really improved the finish and I found I could work out some pretty noticeable scratches and mars with it. I think it is worth the extra run around the car to me.
Old Sep 10, 2016 | 03:24 PM
Den's Vet's Avatar
Den's Vet
Wax on Wax Off
Old Sep 10, 2016 | 06:34 PM
Acid666's Avatar
Acid666
I use a bunch of Adam's Polishing products. One is their glaze. In his videos online he says if you've got a garage queen, the best thing to do is strip it down (wax and all polishes off)... Glaze it, wipe it down, then Wax on top of that. Then every time you take it out and want to clean it you use a quick detailer spray on it. That's how I've been cleaning mine. Spray it down and wipe it with a few microfibers, and then spray it down again and buff it a bit.
If you layer a natural wax, it'll haze up with more and more stacks of it, especially if you don't drive it and give it a chance to wear down (read: Garage queen).
But you can stack the synthetics over and over. So I use the glaze first to make it pop a little, and then a wax on top to help seal it in. The quick detail is just an added layer to make dirt and stuff come off easily and to add more shine.
Old Sep 10, 2016 | 10:00 PM
Haven't tried the Mequire's stuff, but I have used some 3M Professional Hand Glaze on mine and it does do a good job on the finish. May have to look into the Mequire's product.
Old Sep 11, 2016 | 09:44 AM
v8srfun's Avatar
v8srfun
So is glaze like polishing before wax
Old Sep 11, 2016 | 09:57 AM
Deluxe's Avatar
Deluxe
Apparently... and it seems to cut or fill in almost all the surface marks and does a pretty good job with most of the deeper scratches.
The condition my car is in... it is defiantly worth two trips around the car.
Old Sep 11, 2016 | 12:58 PM
terrywerst's Avatar
terrywerst
Yes, it fills in. Great step before waxing. I'd use it alot before shows on my black C5. Worked great!
Old Sep 11, 2016 | 01:49 PM
v8srfun's Avatar
v8srfun
Looks like it is time to add glaze to my routine.
Old Sep 11, 2016 | 08:28 PM
1MRTYME's Avatar
1MRTYME
I like the Race Glaze before applying wax. My 2003 Millennium Yellow princess looks awesome. I use Quick Detail or Mothers to give her a quick cleaning.
Old Sep 11, 2016 | 09:17 PM
1MRTYME's Avatar
1MRTYME
First Weekend I got Cinderella 04/23/2016 (Before Detail)
After detail was finished 05/15/2016
Old Sep 11, 2016 | 10:39 PM
jslym777's Avatar
jslym777
glaze is a filler, it only hides some blemishes, get yourself some compound and a random orbital polisher!
Old Sep 12, 2016 | 07:36 AM
Deluxe's Avatar
Deluxe
Understand that... needs a bit more and will eventually have a good paint job. Saving pennies for now.
Old Sep 12, 2016 | 10:15 AM
Acid666's Avatar
Acid666
There's really nothing wrong with still using it after a paint correction. I did a full correction on the Z06 and on my girlfriend's Kia, and I still glaze it first before waxing. The glaze just really evens it out and makes it pop. The wax then seals that pop in.
Here's the hood of her Kia before and after the paint correction and glaze/wax. (I'd show my Z06, but it's yellow and is really difficult to tell. Hers is black and stands out)
Attachment 48360708
Attachment 48360709
Old Sep 12, 2016 | 06:54 PM
Deluxe's Avatar
Deluxe
Yeah! That's what I'm talking about. Mine is a 50th... a color that really changes as the lighting conditions change. Count it as a dark color.
Old Sep 13, 2016 | 09:31 AM
formula1nut's Avatar
formula1nut
Very impressive. How much of the improvement do you think was the paint correction as opposed to the glaze? I am assuming you paid someone to do the paint correction......right? Approximately how much did the correction cost?
Nice job!
Old Sep 13, 2016 | 06:47 PM
Acid666's Avatar
Acid666
Nice job!
I did it all myself. Harbor Freight has a decent Dual Action Polisher so I grabbed one and ordered some better pads online for cutting and polishing. Went through a few different products before I ultimately ended up with Adam's Polishes products and have been super happy with em. A friend that just got a used Miata as a weekend cruiser and autocross car who's super into detailing suggested I get the Americana Shine Kit (http://adamspolishes.com/shop/kits/w...shine-kit.html) and then buy a gallon of their Detail Spray.
The paint correction wasn't too bad, just some light correction until I saw most of the scratches and swirls gone, follow it up with a polish... Then glaze/wax/detail. My girlfriend is NOT going to keep it up so my intent is to glaze it to give it some shine and fill in some gaps and then use their paint sealer to seal that in for a good 4-6 months. I'm going to use their Paint Correction on my truck as well since it's in the elements 24/7.
But anything that's a garage queen, glaze is awesome for.
Old Sep 18, 2016 | 12:15 AM
jslym777's Avatar
jslym777
the problem with a glaze is that a glaze has no durable bonding properties in it, so when you apply it BEFORE waxing or sealing, the wax/sealant does not get a chance to bond to the clear coat as intended. I was a professional detailer for 11+ years
To Pre-Waxing Glaze
