Jacking pucks.
Old Sep 19, 2016 | 02:54 AM
Rjwz2's Avatar
Rjwz2
Default Jacking pucks.
Are jacking pucks a necessity to jack up your c5 safely? If yes which ones are the ones to get? Do I need an extra low floor jack?
Thanks!
Old Sep 19, 2016 | 03:06 AM
Rob 02's Avatar
Rob 02
There has been a few horror stories on this forum about jacking gone wrong.
I used the hockey puck with the eye bolt with really good results. I had my car at some extreme angles on jack stands for days while awaiting parts. For safety I use extra stands under the cross members though.
I needed a low profile jack long enough to reach the front cross member. The larger harbor freight racing jack works really well IMO.
Old Sep 19, 2016 | 06:22 AM
Dublbubl's Avatar
Dublbubl
The NAPA low profile jack works great and is reasonable price. Yes use Jacking pucks there cheap.
Old Sep 19, 2016 | 06:33 AM
Dan H.'s Avatar
Dan H.
St. Jude Donor '17
Yes, you need them. I bought katech pucks used in the classifieds.
The woodchucks at the "performance speed shop" down the street put my car on the lift and cracked my rocker panel. This makes me soooo happy after i told them to make sure they use the pucks.........
Old Sep 19, 2016 | 09:52 AM
JR-01's Avatar
JR-01
I bought the pucks that snap in and are left in permanently. Great product. It should have come from the factory with them.
Old Sep 19, 2016 | 11:47 AM
I would highly recommend getting some jacking pucks - they help prevent damage to the rocker panels. I use a set of snap in pucks that I got from BMW. They fit great. Some vendors on the forum offer similar style pucks I believe.
Old Sep 19, 2016 | 12:39 PM
OCDvetteman's Avatar
OCDvetteman
I made my own for about 10 bucks. Went down to the local ice rink and got some used pucks, then got eye bolt screws. Had to grind the point of the screw down a bit. They work great!
Old Sep 19, 2016 | 02:23 PM
williame3590's Avatar
williame3590
If you need any pucks there are piles of them along any of our residential streets up here.
Bill
Old Sep 19, 2016 | 04:25 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Here's how to make them.
Old Sep 19, 2016 | 04:27 PM
Rjwz2's Avatar
Rjwz2
Any suggestions for specific brands and suppliers? What about the ones that stay on all the time? Would they get in the way, etc.? Thanks
Old Sep 19, 2016 | 04:59 PM
JR-01's Avatar
JR-01
I have had them in mine for 4 years. Best accessory I have bought for the car.
Old Sep 19, 2016 | 05:00 PM
gimp's Avatar
gimp
I splurged and bought the billet aluminum jacking pucks from Elite Engineering.
http://www.eliteengineeringusa.com/c...pads-set-of-4/
They're very sexy, very solid, have a somewhat anti-slip bottom surface, and have I mentioned that they're billet?
Others prefer the simplicity of snap-and-leave-em jacking pucks, which are a very tough plastic, and simply snap in and never come out.
Elite Engineering also has an aluminum frame rail protector that covers the jacking puck holes, and then you can simply jack up under them whenever you want, which is functionally pretty much equivalent to snap-and-leave-em jacking pucks. I preferred to not go that route.
Old Sep 19, 2016 | 10:25 PM
bluestreak63's Avatar
bluestreak63
I've forgotten about mine a couple times after changing the oil and after spirited runs, they're still intact.
Old Sep 19, 2016 | 11:09 PM
OCDvetteman
Old Sep 20, 2016 | 10:38 AM
Gordy M's Avatar
Gordy M
The BMW snap in plugs are made of a high density rubber and are about 3/8" thick. I have had them in for over 14 years. As an avid autocrosser/HPDE I jack my car up to change tires, suspension, etc over 100 times a year without them ever splitting or breaking. BMW has been using them since the early nineties without any incidents.
Old Sep 20, 2016 | 09:34 PM
JR-01's Avatar
JR-01
Those are the ones I use. Great product.
Old Sep 20, 2016 | 11:00 PM
FX VETTE's Avatar
FX VETTE
I bought the BMW URO jacking pucks others are talking about from Rock Auto (URO part number 51711960752I, set of 4 for less than $35 shipped). I immediately noticed a small amount of play when I snapped them in, particularly on the driver's side - the passenger side seemed to fit a little better.
I've jacked the car up a handful of times and they seem to hold their own. However, I was planning on taking them out anyway because I believe the loose ones may make a rattle noise going down the road. After reading about a similar puck shooting out from underneath a jack in the thread mentioned by thisMSGgood4me -https://www.corvetteforum.com/forums/c5-general/3797719-no-more-plastic-jack-pucks.html, I'll be making the change to an easily removable aluminum version asap.
To Jacking pucks.
Old Sep 21, 2016 | 12:25 AM
Rjwz2's Avatar
Rjwz2
Originally Posted by jptgs1
. I'm a diy guy so I like your idea and just ordered 4 from eBay. Not too many hockey players in Hawaii! Thanks for the video.
Old Sep 24, 2016 | 05:41 PM
Rjwz2's Avatar
Rjwz2
Thanks Jeff, I just finished making mine. They came out great. Used the exact hardware that you specked except the drill bit sizes. Yours were too small. I used 5/16" for the eye bolt and 3/8" for the t-nut.
Rob.
Old Sep 24, 2016 | 09:17 PM
joendoodle's Avatar
joendoodle
Thanks!
Need: yes.. I made similar to the "used" Hockey pucks, used soft (pine) wood and I bolts.
Lo profile jack, I got one to use on the C4 and also (now) use it on the C5... so I'll say yes... before I had the Lo Profile jack I would drive my C4 onto 2X6's to use the "regular" jack..
