Time for oil change?
Old Sep 21, 2016 | 01:33 AM
Harley6's Avatar
Harley6
From: Phoenix (Fall/winter/spring); Seattle (summer)
2015 C5 of the Year Finalist
Default Time for oil change?
My last oil change was exactly a year ago, and I've put only about 1,200 miles on my 03 Coupe since then. And like many of you, it will spend most of the winter in the garage.
What's the consensus here on oil change intervals? Should I do it every year regardless of miles?
Old Sep 21, 2016 | 02:11 AM
Rexde1's Avatar
Rexde1
Once a year if you dont put a lot of miles on.
Old Sep 21, 2016 | 03:10 AM
C5Natie's Avatar
C5Natie
Change it. Cheap insurance. Oil still sees condensation and moisture with temp changes in the crankcase. This builds acids and can cause sludge.
Old Sep 21, 2016 | 03:17 AM
Harley6's Avatar
Harley6
Thanks for the replies. When is the best time to change it, just before it sits for much of the winter or in the spring when I'll be driving it more? Or does it matter?
Old Sep 21, 2016 | 03:56 AM
Tuco's Avatar
Tuco
St. Jude 15 Year Donor
From: Blessed are the cracked. For they are the ones who let in the light.
St. Jude Donor '08 thru '26
With that low mileage it should not be that dirty, so I would do it later.
But I am sure many here will disagree.
My thought process runs to having fresh oil and being under the car to make sure everything else is copacetic at the start of the season.
Of course I might catch hell that I should do that every time anyway..
Still I will not change.
Old Sep 21, 2016 | 07:04 AM
oh1vette's Avatar
oh1vette
Never mind time to change the oil----Time to drive that thang!!!
Old Sep 21, 2016 | 07:08 AM
C5Natie's Avatar
C5Natie
I'd suggest in the spring so you have fresh oil in it when you start driving it
Old Sep 21, 2016 | 07:26 AM
LoneStarFRC's Avatar
LoneStarFRC
Yes.
Old Sep 21, 2016 | 07:29 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Old Sep 21, 2016 | 09:10 AM
c4cruiser's Avatar
c4cruiser
A Springtime oil change will work fine, but I would suggest running the engine just before the oil change for some time such as taking a 20-30 minute drive so that the oil temp gets up to the normal operating temp (180-200 degrees). That will help to burn off any condensation in the engine and the exhaust system.
Old Sep 21, 2016 | 09:30 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
That's how I was taught.
Old Sep 21, 2016 | 09:43 AM
thornyc503's Avatar
thornyc503
I agree once a year if you keep low miles. What kind of oil are you running?
Old Sep 21, 2016 | 10:03 AM
The Owner's Manual says that if you do not drive the car enough miles for a normal oil change to be needed, then change the oil once a year. I too only put about 2-3K miles on mine each year and I change the oil as I put it in storage for the winter.
Old Sep 21, 2016 | 11:23 AM
mrlmd's Avatar
mrlmd
If you're worried about acids and condensation sitting in the engine for a prolonged time, then why would you want to store the car with "dirty" oil in it for 6 months 'till you change it? It makes much more sense to change it before layaway and that's what most mechanics would recommend. That's also what is standard practice in all the boat yards when boats are hauled out and stored for the winter. And fill up the gas tank to minimize the air space inside to prevent that little bit of moisture from condensing on the cold surface and contaminating the fuel.
Old Sep 21, 2016 | 11:26 AM
moekluse's Avatar
moekluse
Last year I changed oil and filter, its been sitting for this whole year and has accumulated under 30 miles, before I go take it out and drive it, i would highly recommend changing oil and filter, either every year or 5000 miles
Old Sep 21, 2016 | 03:33 PM
knewblewkorvette's Avatar
knewblewkorvette
Sorry, I disagree. The research I've done in the past says it's better to change the oil before storage.
Old Sep 21, 2016 | 03:36 PM
66dts-v's Avatar
66dts-v
Wow, I can't even imagine. I'd be lucky if I hit 3 months before I hit 5k miles (have yet to hit the 3 month mark in 2 years). Well, maybe this interval since I haven't been driving it waiting for my new parts to show.
To Time for oil change?
Old Sep 21, 2016 | 03:40 PM
Dublbubl's Avatar
Dublbubl
Some say that with synthetic oil it's more about miles driven on then time in the car. Most condensation will burn off at normal operating temps. But it's more for peace of mind and to look under the car while its up on the lift. Walmart sells 5/30 Mobil 1 for $22 5 quart jug.
Old Sep 21, 2016 | 03:49 PM
Black 02's Avatar
Black 02
Once a year or 5k miles for me, whichever comes first. I usually change mine each time I renew my registration sticker so it's easy to remember when it's due.
Old Sep 21, 2016 | 05:26 PM
Corvettewaldon's Avatar
Corvettewaldon
I change mine a month or so before storage, and then in the spring when I do the once over maint for the summer. Prob overkill, but I don't like to run it with the oil after winter. Just my 2 cents.
