Tire sensor 2004
Old Sep 22, 2016 | 08:51 PM
johnfin's Avatar
johnfin
Default Tire sensor 2004
I did the fob programming with the magnet method and the last stem would not sound off, does the mean its toast? Which is the correct p/n for a 2004 base model 25773946 or 17801156
Old Sep 22, 2016 | 09:22 PM
JR-01's Avatar
JR-01
Did you try more than once?
Old Sep 22, 2016 | 10:45 PM
johnfin's Avatar
johnfin
Default Sensor
Yes, worked at it for along time. Could explain the tire mon. Warning all the time.
Old Sep 22, 2016 | 11:12 PM
SG Lou's Avatar
SG Lou
The batteries in the monitors are good for about 8 yrs, 10 if your pushing it. I have an 04 as well and replaced them a few years ago. Better safe then sorry.
On a side note: Schrader makes the TPM's for GM.
Old Sep 23, 2016 | 10:45 AM
johnfin's Avatar
johnfin
Default Sensor
Can i install a new sensor and use the magnet fob programming method or do i need a tech ii
Old Sep 23, 2016 | 06:00 PM
SG Lou's Avatar
SG Lou
Originally Posted by thisMSGgood4me
Depends on the brand of sensor you install. If it's ACDelco or Schrader (which makes the sensors for ACDelco), then yes, you use a magnet to train them. Other brands of sensors might use other methods of training.
with what he said.....Get the Schrader , get it installed and program yourself with a magnet !
Old Sep 24, 2016 | 05:51 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Also with the ACdelco/Schrader you can program them before installation to make sure they work. It is easier that way too. Just mark them to be able to put them in the right position when you get them mounted in the wheels.
To Tire sensor 2004
