Upper control arm rear
Old Sep 23, 2016 | 06:25 PM
c5mtl's Avatar
c5mtl
Default Upper control arm rear
I'm pulling a half shaft to change a boot and I'm just checking all the rear suspension. I just want to know if the upper control arm is supposed to be easy to move up and down when it's complete separated from the rest of the assemble but still toqqued to spec.... mine seems to be stuck and not move much. I'm sure it moves fine with the weight of the car moving it but I do remember seeing a video showing the upper and lower arms moving really easy
Old Sep 25, 2016 | 03:29 AM
Rob 02's Avatar
Rob 02
The rubber is cast into them (unless you have installed poly bushings). With the bolt loose it moves easier.
