LMC5 install issue, column lock
Old Sep 24, 2016 | 08:26 PM
Totall84's Avatar
Totall84
Default LMC5 install issue, column lock
After having my steering column locked up, I bought the LMC5 kit and it worked in a sense. The steering column is no longer locked up and it drives fine now, however now my display is all crazy. Has anyone experienced this and if so how did you fix it?
Old Sep 24, 2016 | 09:42 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
I've never seen that before!! I would contact Richard and see what he has to say.
Have you tried pulling the codes again??
Old Sep 24, 2016 | 10:01 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Did you have the batt disconnected ??? remove neg cable for 15 min reinstall, then report !!!
Old Sep 24, 2016 | 10:13 PM
Totall84's Avatar
Totall84
I disconnected the battery, and unplugged everything on the bcm. I plugged everything back in and it works perfect, so I guess there was a loose connection somewhere. Hopefully this will help someone in the future.
Old Sep 24, 2016 | 10:19 PM
Sometimes electrical glitches happen and a battery disconnect and re-connect resets things. Good that it worked for you this time.
Old Sep 24, 2016 | 10:57 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Sorry I now remember that happening to me, I had mine on a battery tender and turned the key to on !!! I had never seen that before and I remembered that I disconnected the batt for a while and all was good. A side note is I have my tender hooked to the positive and ground on the alt. //// I didn't know if that was what cause my malfuntion, as we all know the C 5 is a different cat !!!!!!!
To LMC5 install issue, column lock
