Audio problems with new head unit
Old Sep 26, 2016 | 09:05 AM
Willyum's Avatar
Willyum
Default Audio problems with new head unit
So I got a double din bezel and a double din head unit for my car (ken wood ddx9703) and then everything is ok until I turn on the radio and the audio is terrible. There is virtually no bass whatsoever and the audio quality is really poor. Does anyone have any suggestions on how I can get the stock sound back from my Bose speakers?
Old Sep 26, 2016 | 12:33 PM
garline14's Avatar
garline14
Did u use the pac roem vet1 wiring adapter for the install? If so u may have to adjust the potentiometers to get the sound just right.
Old Sep 26, 2016 | 01:47 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
Maybe contact Dennis @ Double D Mods for some advice and assistance
Old Sep 27, 2016 | 01:21 AM
striper's Avatar
striper
Kenwood radios have a multitude of audio adjustments. I had the same problem with mine. You've got to spend some time figuring all of that stuff out. It takes time but you can get it better. Make sure you find the setting save button. I disconnected my battery and had to do it all over. Ultimately I think even inexpensive speaker replacement is in the cards for me. The Bose speakers just aren't that good.
Old Sep 27, 2016 | 08:06 PM
olbear1962's Avatar
olbear1962
If your budget allows I would definitely look at aftermarket speakers.
Definitely contact Dennis at DD Mods, a great forum vendor and always willing to assist folks with their audio issues.
He will be able to give you a number of options, and tailored to your budget.
Old Sep 27, 2016 | 09:12 PM
alcoed's Avatar
alcoed
Default great sound
You invested in a quality head unit, now complete the job. I installed a 8 inch mid, mid/bass speaker and a 3 1/2 tweeter in each door using the factory bose mounts. A 6 1/2 co axial in each quarter and an amplified 10 inch sub in a ported and baffled enclosure in the center storage well. You can use the factory speaker wiring, but have to add new sub wiring.
The sound is awesome!
Old Sep 28, 2016 | 08:44 AM
GCG's Avatar
GCG
There's no reason for it to sound worse than OEM. This is an upgrade, not a downgrade
Before tinkering with the new headunit's adjustments, first make sure the PAC adapter (if you used one) is adjusted right: if the source is not good, what you get at the end of the chain is not going to be good either.
To Audio problems with new head unit
