[Z06] Starting my LS3 Swap
Old Oct 7, 2016 | 03:00 PM
Drewster67's Avatar
Drewster67
Default Starting my LS3 Swap - EDIT: Swap Done.
Ill be posting pics as the build moves forward but for right now, I ordered all the parts for the swap including the 376/480 LS3 Crate engine.
Also went with a Dewitts aluminum radiator with oil cooler and oil cooler lines kit.
On the back end, Ill may have my LS6 to sell (minus the parts needed for the LS3 swap)
The LS6 needs the bottom end gone through to replace the main bearings but still runs strong and was dynoed at 351 RWHP in 2014. At this time I'm not sure if I will sell (if at all) the LS6 as is or after repair.
As time moves on, Ill post pics - Car goes into the shop on Tuesday (10/11/2016) to start the swap.
Old Oct 7, 2016 | 03:23 PM
danziger's Avatar
danziger
Awesome! I will be following along...
Old Oct 7, 2016 | 06:47 PM
danh52's Avatar
danh52
I love my LS3.
Question, why didn't you go with the 500hp version? I think it has a slightly more aggressive cam, not sure of the spec's.
Anyway, good luck with the swap.
Old Oct 7, 2016 | 06:50 PM
Drewster67's Avatar
Drewster67
Originally Posted by danh52
I love my LS3.
Cost .... Im on a budget.
Thanks man.
Old Oct 12, 2016 | 10:23 AM
Drewster67's Avatar
Drewster67
Default Its Happening.
My 376/480 Motor arrived yesterday and the LS6 motor is being broken down. All parts are here so its just a matter of getting her done and on the Dyno after break in.
Ill post more Pics this weekend. Not much else going to happen this week.
Ill be detailing the entire engine bay before the new motor is installed.
Peace
Old Oct 14, 2016 | 07:54 AM
nsogiba's Avatar
nsogiba
Looks nice. What are you looking to get for the LS6 motor?
Old Oct 14, 2016 | 10:47 AM
Drewster67's Avatar
Drewster67
Thanks!
I havent decided what to do with it yet.
It has an issue with low oil pressure when warm. The census is the main bearings are going out.
It is a Thompson Motorsports LS1/LS6 replacement short block with forged internals rated to 700 hp. Tuned at 351 RWP
I may just fix it then sit on for a future project of if someone made me an offer I couldn't refuse ....
The motor should be out Sunday.
Old Oct 14, 2016 | 02:43 PM
Thompson Motorsports's Avatar
Originally Posted by Drewster67
Thanks!
How old is the Thompson Motor? Give us a call when you have a sec, We can likely help you even if it is for another project in the future.
Thank you,
Kyle
972-853-2450
Old Oct 14, 2016 | 02:57 PM
Thank you for reaching out OP. It was a pleasure speaking with you. I look forward to working with you more in the future. If we can help you with anything please do not hesitate to call or ask.
Thank you,
Kyle
972-853-2450
Old Oct 14, 2016 | 02:59 PM
Drewster67's Avatar
Drewster67
Thank you,
Kyle
972-853-2450
Thanks Kyle - much appreciated and I definitely will be in touch!
Old Oct 17, 2016 | 04:29 PM
Drewster67's Avatar
Drewster67
Default LS6 is out
Getting closer ...
Old Oct 17, 2016 | 04:52 PM
danziger's Avatar
danziger
I love engine swaps. Keep up the strong work!
Old Oct 18, 2016 | 01:04 PM
Drewster67's Avatar
Drewster67
Time for some cleaning before the LS3 goes in
Old Oct 18, 2016 | 01:18 PM
ENV MN's Avatar
ENV MN
5th Gear
I look forward to following this. I am in the market for a roller C5Z or C5 FRC so I can start it right away as a project. Just not easy to find one.
Old Oct 18, 2016 | 01:23 PM
Drewster67's Avatar
Drewster67
Cool Cool
Old Oct 18, 2016 | 02:42 PM
Drewster67's Avatar
Drewster67
Looks like the clutch needs attention - rather than replace the disks, Im just going to replace the entire clutch assembly.
Anyone have a lead on the best place to get a clutch for my swap?
I need it by Friday at the latest.
TIA
Drew
Old Oct 18, 2016 | 02:45 PM
nsogiba's Avatar
nsogiba
I had real good luck with an OEM LS7 clutch in my old car (6.0 LS swapped BMW). I got it overnight from Summit Racing for a good price (pressure plate, clutch disk, and flywheel). I live in Buffalo and got it overnight at regular shipping price from Cleveland.
I see you're in Gilbert AZ - I think Summit has a location in Reno, NV. Might be worth a shot.
To Starting my LS3 Swap
Old Oct 30, 2016 | 03:14 PM
Drewster67's Avatar
Drewster67
Had a week delay but things are moving forward again.
I decided to replace the Mantic Er2 Clutch (with only 32k miles) for a brand new Mantic Er2. Took 5 days to get here.
Now, the only thing I'm missing, which I just found out today, is the MAP extension harness.
She's getting closer.
Old Oct 30, 2016 | 03:24 PM
Drewster67's Avatar
Drewster67
Not my pic but this is the clutch that went in.
Old Oct 30, 2016 | 07:14 PM
danh52's Avatar
danh52
Great build!
How hard was it to line up the new engine with the torque tube input shaft?
