Coolant Tank - Leaking?
Old Oct 8, 2016 | 05:12 PM
craig_vette's Avatar
craig_vette
Default Coolant Tank - Leaking?
So I finished replacing my wiper motor's pulse board today, and right as I was closing the hood, I noticed orange goo on/around the coolant tank. You can see it in the pics below around the edge. What would cause this? I've cleaned the engine bay before so I know it must be a recent occurrence. The coolant has NOT been added to since then so it's not overspill. Any idea?
Old Oct 8, 2016 | 07:08 PM
craig_vette
The leak seems to be coming from this hose connection point. It's like it's not tight enough. How would I tighten it?
Old Oct 8, 2016 | 07:09 PM
craig_vette
pics of connection
Old Oct 8, 2016 | 07:31 PM
Are you sure there is not a crack on the plastic nipple on the tank? That would be my guess.
Old Oct 8, 2016 | 08:30 PM
craig_vette
If there's a crack on the nipple, could I use RTV silicone?
Old Oct 8, 2016 | 11:06 PM
zachaeous's Avatar
zachaeous
The tank on my 2001 was leaking in that exact spot. I just replaced mine instead of trying a repair. Good luck.
Old Oct 9, 2016 | 02:12 AM
sirdano's Avatar
sirdano
Mine was leaking there too. I push the hose as far as it would go and put a screw clamp on it.
Save buying another tank
Old Oct 9, 2016 | 10:47 AM
TXGS507's Avatar
TXGS507
Very common.... Mine did the same thing in the same spot. Purchased a new GM tank on Ebay.
To Coolant Tank - Leaking?
