C5 Corvette Bolt-On Coil-Over Kit By Aldan American Suspension @ RPI Designs
Platinum Supporting Vendor
Please note, this item is fully discounted and not discounts can be used. We do offer free shipping on this item.
Aldan Corvette coil-over kits allow you to replace factory shocks & mono springs with ride-height adjustable coil-overs. Upgrading to coil-overs will drastically improve handling, responsiveness and putting power to the ground on your C5 Corvette. If you’re looking to properly lower your vehicle and improve your ride quality – This kit is for you.
Included
•100% Made in the U.S.A.
•CNC Cut & TIG Welded Bracketry
•Phantom Series – Single Adjustable Coil-Overs
•2.5" ID High Travel Coil-Springs
•100% Bolt-On Design
•Grade 8 Hardware
Benefits
•Easy Installation Using Basic Hand Tools - No Drilling, No Cutting or Welding Needed
•Ride Height Adjustable – Lowers Vehicle 1”-1.5” Lower Than Stock Height
•Powdercoated Brackets – Durable, Long Lasting
•Serviceable – Serviceable & Rebuildable By Aldan American or Aldan Approved Service Center
•Front/Rear Mounting Design – Offers Greater Strength & Better Weight Distribution
This kit comes with the 500 lb front and 550lb rear springs which from testing on the Street and Track they have determined this is the best overall package. Other spring rates are available upon request. If you have any questions please feel free to call Don at 888-257-8515 ext 2.
Aldan American Corvette Coil-Overs
While not a C5 Corvette our in-house tech specialist and salesman Don Stellhorn has been running these shocks on his road racing 1964 Pontiac GTO for over 11 years and has never had a problem with them. Aldan American develops, tests and manufactures their full-line suspension products in Los Angeles, California. U.S.A. Every Aldan shock, coil-over, spring and suspension component they offer is sourced and manufactured using the highest quality materials found here in the U.S.A.
Item # C5SB4 Please click on link below for more information
Website Link : http://www.rpidesigns.com/shop/item....an-suspension/
Included
•Grade 8 Hardware
Benefits
__________________
This is a great coil over kit that will help improve the handling of your C5 Corvette, if you have any questions or would like to place an order you can reach me at 888-257-8515 ext 2. Thanks, Don
