Traction control
Old Oct 13, 2016 | 03:22 AM
gmbal4's Avatar
gmbal4
Default Traction control
So when I turn traction control off it almost seems I have a new found
amount of power car pulls very hard. Does anyone know how much power is taken away with traction control turned on ??
Old Oct 13, 2016 | 06:38 AM
Murray Anderson's Avatar
Murray Anderson
Whatever power the car deems necessary to stop the tires from breaking loose. It depends on too many variables to give a number.....street condition/type, temperature, tires etc.
Old Oct 13, 2016 | 11:14 AM
vetintheblood's Avatar
vetintheblood
From: Beavercreek Ohio Currently own: 1958 Silver Blue Corvette & 1969 Riverside Gold Corvette Coupe
2025 C1 of the Year - Unmodified Finalist
Just be careful with all that power! Good luck
Old Oct 13, 2016 | 12:51 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
one of the things it does is retard the timing !!!! When I first got mine and would floor in first or second I thought what a dog. Felt like something was holding it back, read up on the TC and turned it off. Then floored it in the first two gears and it just lit up the tires. I still leave it on !!
Old Oct 13, 2016 | 01:27 PM
RockyMtC5's Avatar
RockyMtC5
I will put mine in Competitive Driving mode if I'm getting aggressive, which still keep traction control active but allows more spin than normal. Rear tires are expensive and I prefer to not smoke them very much so I hardly ever turn traction control off.
Old Oct 13, 2016 | 02:31 PM
Murray Anderson
Correction..... competitive driving mode turns off TC but keeps active handling engaged
Old Oct 13, 2016 | 02:59 PM
crazybird's Avatar
crazybird
I too leave the TC on most of the time. But its fun every now and then to burn some rubber!
Old Oct 13, 2016 | 03:00 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Old Oct 13, 2016 | 03:14 PM
RockyMtC5's Avatar
RockyMtC5
Thanks for the clarification, I wasn't totally sure what it was but I could tell it kicked in when the car started getting sideways
Old Oct 13, 2016 | 11:57 PM
gmbal4's Avatar
gmbal4
thanks Guys
Old Oct 14, 2016 | 12:03 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Per owners manual !!
Traction Control System (TCS)
Your vehicle has a traction control system called TCS
that limits wheel spin. This is especially useful in
slippery road conditions. The system operates only if it
senses that the rear wheels are spinning too much or are
beginning to lose traction. When this happens, the
system works the rear brakes and reduces engine power
(by closing the throttle and managing engine spark) to
limit wheel spin.
To Traction control
