Memory Buttons Issue, Help Please
Old Oct 13, 2016 | 04:12 AM
CorvetteBob52's Avatar
CorvetteBob52
Default Memory Buttons Issue, Help Please
I am having trouble programming my memory buttons on the drivers door, Im guessing that you put everything in the positions you want, Seats, Mirrors, and the telescoping steering wheel and then push and hold the memory selector button down until it goes out, then Its supposed to be set, but it doesn't stay set, still goes back to a crazy setting that I have to adjust every time I drive the car, Can anyone please explain how to set this correctly? I have the two setting memory buttons numbered 1 and 2 left and right. Thank you for any info on this. CorvetteBob
Old Oct 13, 2016 | 08:43 AM
FX VETTE's Avatar
FX VETTE
Do you still have your owners manual? It should have the instructions and they are pretty easy to follow.
Old Oct 13, 2016 | 12:53 PM
Carl Timonen's Avatar
Carl Timonen
Also remember to shut the door before inserting your key.
Old Oct 13, 2016 | 01:16 PM
Efx's Avatar
Efx
Also make sure that the car is parked position and not moving.
Old Oct 14, 2016 | 03:46 PM
az57chevy's Avatar
az57chevy
I'm guessing you may be swapping out the fobs? Does the "crazy" settings stay consistent each time. Use fob 1 to start with. Start the car and turn off. Then go ahead and set the memory for driver 1, save it and walk away, locking the car. with the fob. Now come back and get in and you should be set. Remember the driver's seat always retracts to allow for easier access/egress and then goes to the pre-set location
Old Oct 15, 2016 | 09:08 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Originally Posted by 8VETTE7
If you do not use a FOB to unlock the car then you have to manually press the button for which you want the settings to be restored.
Did not know that, but that's what I have been doing.
Thanks!
To Memory Buttons Issue, Help Please
