Buying a C5 - problems fixed?
Also...fully agree with the above post....Pounders
I think you and I may be talking about two different things. I think you're saying these cars are now getting up there in age and things are bound to go wrong with them because of their age. That is very true and expected. However, what I'm talking about are the common issues, most of which are because of manufacturer defects/design problems that came from the factory. Things like the steering lock, EBCM, etc are design flaws and should've been fixed with recalls. Design flaws not covered by recalls by this time should have presented a problem which should have been addressed by the previous owners in their 12+ years of existence. These are separate issues...I expect to have issues due to age and the wearing out of parts, but the known issues that were included with the car when it was new should be resolved by now in most cases...at least in theory anyway...and I'm actually pretty handy when it comes to turning wrenches!
https://www.corvetteforum.com/forums...must-read.html
Back in 2005 these cars were not OLD but the problems were WELL known even then.
As stated above, if you cannot work on your own car they could be expensive to own. Labor, whether at a Stealership or private garage, is NOT cheap.
If you say the chances of finding a car that still has many of the original problems not fixed are good, then let me ask you this. How many of these original problems can just be ignored? Obviously, the steering lock problem can't be ignored as it completely disables the vehicle when it occurs. I don't know that much about the EBCM problem, but doesn't it affect the anti-lock braking system and handling? Seems like that would also be something that the owner would have to fix when the problem occurs. I'm sure there are some defects that could just be ignored, but it seems to me that most are either disabling, or so annoying if left unfixed that it would be too annoying to live with. The early model C5s are approaching 20 years old now and the likelihood of these problems not occurring to their previous owners after all these years just seems remote to me...
This is all at 140k, but I drive my car the way god intended, so I wear stuff out. I hope once it's all done I'll have another 3+ years and 100k miles out of it. I love this car.
<edit> Breakdown:
Purchase price: $14,250
Clutch: $2500 ($1000 parts and $1500 labor)
Wheel hubs: $350
Ball Joints: $200
End links: $100
Tires: $600
Misc: $250 (LMC5, bulbs, flasher)
Brakes: $300 for slotted rotors and new pads
That's what my car has cost me over 2 years and 70K miles. Besides a LOT of gas and a ton of oil changes, I would say that is nothing compared to my friends with older BMW's. And I've averaged 26mpg
<edit2> I still need to fix my oil pressure sender, I've been lazy and I don't want to pull the intake off.
Any car a decade old is bound to have electrical issues eventually.
I guess the LMC5 is an inexpensive fix, but there are some of the common problems that aren't so inexpensive, I'm sure... doesn't sound like you've had many problems, I hope that trend continues for you!
Either way, it would be better to find a car that's had the problem come up, and had it fixed, than the other way around...
As far as the level of annoyance one can tolerate, that is an individual thing. YOU have to decide on what lights showing on the dash will annoy you.
Which failures any given car will encounter is a crap shoot at best. MOST will experience at least some of the failures. No way to predict in advance what is going to happen to which car. Wasn't there a song that said "what will be will be"??
So if the EBCM goes bad you get a warning light, and the ABS, TC, and AH cease to function, but the car is still drivable without having to bypass, or reset anything to do so?
<edit> on the '01+ you unplug it and mail it in for repair and you can drive your car around without it if you'd like.
I've fixed all these things except for the axle seal and the seat. I have yet to encounter the column lock issue or EBCM failure, but I keep an LMC5 in the glove box just in case.
However, this...
... I do agree with. It's pretty much universally accepted that C5s susceptible to column lock issues should immediately have a CLB or LMC5 installed if they do not, regardless of their current status. Considering the issues this causes there's no reason for it not to be present. I've come across a tremendous amount of C5s that have not have CLBs installed and in conversing with some owners some who aren't forum savvy don't even know it's a potential issue.
But for sure, yeah, in your look for a car if you're expecting to find a car that is well sorted out with pre-emptive items serviced you're not going to find it. At best you'll find a car with well detailed service records, which would be ideal.
