Protective cloth under vert top
Old Oct 20, 2016 | 12:52 PM
Navygator's Avatar
Navygator
2nd Gear
Default Protective cloth under vert top
With the windows down and top up the cloth protective cloth will blow up into the back window. Am I doing something wrong here?
Old Oct 20, 2016 | 01:18 PM
Murray Anderson's Avatar
Murray Anderson
Don't know if it's wrong but another issue is high speeds while windows are down and top is up..... continuously do this and soon you'll be asking how to put the rear window back in
Old Oct 20, 2016 | 04:10 PM
El original's Avatar
El original
LOL, the protective cloth is secured by two elastic straps to keep tight to rear cowling. They are there somewhere but have come loose from protective cloth (or cut off by PO) Look for ends of black elastic straps and re secure to cloth. Keep cloth as it protects the glass from scratches.
Old Oct 20, 2016 | 04:46 PM
kpcets's Avatar
kpcets
Veteran: National Guard
My straps are there but over the years have been stretched out so not really doing anything. I just live with it because if the windows are down usually the top is too.
Old Oct 20, 2016 | 04:53 PM
rrwirsi's Avatar
rrwirsi
Old Oct 20, 2016 | 08:22 PM
CorvetteBob52's Avatar
CorvetteBob52
Originally Posted by rrwirsi
I had the same problem. I just cut mine off. I don't put anything inside the car that would scratch it anyways. Never had a problem since.
Old Oct 20, 2016 | 10:42 PM
BAT's Avatar
BAT
2026 Corvette of the Year Finalist - Modified
2025 C7 of the Year Winner - Modified
2024 C7 of the Year Finalist - Modified
2023 C7 of the Year Finalist - Modified
2021 C7 of the Year FinalistAX - Modified
Same here. Drives me nuts so I've only put the windows down half way, at best. Is that cloth supposed to flap around like that?
Old Oct 20, 2016 | 10:50 PM
K9Leader's Avatar
K9Leader
I hated that thing on my '99 so I removed it shortly after I got it in 2010. Never miss it.
To Protective cloth under vert top
