A/C Puddles
Old Oct 29, 2016 | 06:53 PM
Saltywheels's Avatar
Saltywheels
Default A/C Puddles
Never seen such large water puddles under the car, after using the A/c on my newly acquired 2001 C5. Is this normal? Just want to be sure something else ain't wrong. Thks
Old Oct 29, 2016 | 08:00 PM
As long as it is just plain water, you should be OK. My car at times does leave a large puddle of water under it, especially if it is really humid outside. Just make sure it is also not the windshield washer tank with a leak.
Old Oct 29, 2016 | 08:56 PM
JR-01's Avatar
JR-01
The more humidity the bigger the puddle. If it isn't pure water you've got a problem.
Old Oct 29, 2016 | 11:34 PM
Choreo's Avatar
Choreo
Normal on my 2001.
Old Oct 30, 2016 | 01:18 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I know someone that saw an oily puddle and thought it was his oil pan leaking and had it resealed at a stealership.
Turned out to be A/c leakage (the puddle disappeared and happened again afterwards) and he wasted over $550 if memory serves correct.
Old Oct 30, 2016 | 03:17 AM
Saltywheels
Phew!! was a wee bit worried initially. But am sure it is plain ole water! Felt it & smelt it!
Old Oct 30, 2016 | 07:27 AM
bigcypress's Avatar
bigcypress
be glad to see the puddles . i didn't see them but never gave it much thought . i ended up with a close to $500 repair .
Old Oct 30, 2016 | 10:31 AM
c4cruiser's Avatar
c4cruiser
The water is condensation created from the A/C operation. Pretty common when there is a lot of heat with humidity or even rain. Might try running the A/C in defrost/defog mode with full heat. That will work to aid in evaporation of moisture that collects in the bottom of the system.
Old Oct 30, 2016 | 10:49 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
The bigger the puddle the better your AC is working. And, you know the drain is working if the water is under the car and not in the passengers footwell.
To A/C Puddles
