[Z06] C5 z06
Old Nov 3, 2016 | 04:19 PM
bobbyknudsen's Avatar
bobbyknudsen
4th Gear
Default C5 z06
I cannot shift into reverse , throw out bearing has been making a grinding sound.Do I need to install new Clutch Kit
Old Nov 5, 2016 | 08:43 AM
bikeriderga's Avatar
bikeriderga
No offense, but didn't you just answer your own question?
If the throw out bearing is bad (unless you just installed one and it happened to be defective), 90% of the time, it will be time to change out the clutch as well.
At the least I would plan on it. That way if the clutch and pressure plate look fine, just count it as a bonus. Doubt that will be the case however.
Old Nov 5, 2016 | 08:33 PM
racebum's Avatar
racebum
if you have been driving with a bad TB you better hope that's all it needs. an unsupported input shaft under load can wreck the shaft and the bearings it rides on
Old Nov 5, 2016 | 09:21 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Check front torque tube bearings while you have it apart. Consider a remote bleeder as well. I wish I added that last time around.
To C5 z06
